chevy 350 240 sx
Old Dec 12, 2003 | 01:24 PM
crib34's Avatar
Arrow chevy 350 240 sx
Does anyone have any information on the chevy 350 swap into a 1989-1993 fastback. I've seen one car with the swap and my friend and I want to check into it.NEed INfo on hubs and axle combonations. Just checkin out there. THanks
Old Dec 12, 2003 | 01:58 PM
Judge's Avatar
Usually when someone does a swap like that the stock rear axle stays in the car and they modify the driveshaft to fit the new trans. If you wanna do something like that think about doing a 327 or even 283 with a5 speed trans. 283 would be fun due to its reving ability and light (considering its 60's tech).....but there are alot better alternatives...up to you. I have been in the auto industry for years and have put engines in things they say will not work....its all about how dedicated you are and what the final outcome is.
Old Dec 12, 2003 | 05:28 PM
irax's Avatar
the LT1 motor is a popular domestic motor swap because practicly all you need is just bigger motor mounts and the stock drive shaft should work, but im not sure. A friend of mine has done an LT1 into a 240z and all i know is that it beats evo 7 like nothing
Old Dec 12, 2003 | 07:33 PM
Its been posted here...search for V8 240 or sumthing like that
Old Dec 12, 2003 | 09:43 PM
NightXCZ77's Avatar
You'll get a bunch of people like me against the idea when you look up the thread....KEEP NISSAN, NISSAN!!!
Old Dec 13, 2003 | 12:19 AM
Yep....u will probably get TONS of beef you go threw with a Domestic V8, lots of haters.
Old Dec 14, 2003 | 09:40 AM
Sil40_Mayhem's Avatar
i'll say that while i'm not a big fan of cross-make motor swaps, i think that u should do what ur money and ur judgement allow u to. and as far as brand loyalty, Holden (Australian GM Subsidiary) has been known to drop in either 5.7L GM V8's OR Nissan RB series motors (look up the Holden Commodore ). so if car manufacturers don't have a problem with it, then...?
Old Dec 16, 2003 | 09:13 PM
hashiriya13's Avatar
The Lt1 has been put in a s14. some guy on nico. should be a similiar set up for the 13. I have thought about doing it for my new 13 and keeping it an auto for the wife. But still undecided and projects for me are on hold for maybe up to a year. But my plan is to go 383 stoker with super charger if I go that route in the future. Like sil40 said do what you want who care what others think. Its your car. With a v8 not many will be able to say anything anyway unless you let them catch up.
Old Dec 19, 2003 | 02:31 AM
irax's Avatar
exactly
HP = HP and TQ = TQ no matter who makes it, if you can afford it, and put it in your car, and you WANT to do it ? whats stopping you ? ohh and i found out, that all you have to do is get motor mounts that lift up the engine at an angle so the driveshaft fits correctly... thats pritty much it, you will be using the LT1's tranny and the host's driveshaft..
Old Dec 23, 2003 | 04:40 PM
2240sx's's Avatar
Wouldn't one need to have a custom driveshaft made so it'll connect with the tranny and the rear end right?
Want about the tq issue? Will that poor unibody be rip to shreads by a 383 supercharged?
Old Dec 23, 2003 | 05:44 PM
Catharsis's Avatar
i am doing a 5.0(302) ford in my car with aluminum head i will keep it about the same weight and i can mount it lower if needed anyways way more tourqe hp and better gas milage cause i will never have to go about 2k rpms street driving... and i can skip 2nd and 3rd so 1st to 5th....
i say go for it
Old Dec 23, 2003 | 10:13 PM
The set up I have thought about for the 383 would only be 4-500hp now tq is another issue but there are pleanty of silvia/180's in japan in that HP range and even more parts for the car to be able to handle the tq. Just keep in mind this was just a thinking plan not something I plan on doing anytime soon but maybe in the future.
Old Dec 30, 2003 | 09:48 AM
slp240's Avatar
I came across a guy in Michigan that does V8 conversions in anything that is rear wheel drive. He sells the kits needed to complete the swaps. send me an email address and I can forward his info to you
image 1 image 2 image 3 image 4
aznromeo804
Jul 10, 2007 05:55 AM
jturbo06
Jun 21, 2007 08:56 PM
V8-240sx
Jun 14, 2005 11:52 AM
V8-240sx
Mar 2, 2003 06:35 PM
dennis
Feb 2, 2003 06:21 PM
