curious
Old Nov 17, 2002 | 09:30 PM
altima/240sx's Avatar
curious
Most likely this has been asked before, but i will ask anyways. If I was to get a SR20DE motor and get a turbo kit off a DET will it all be worth it? and what all would i need to change to make it worth it. I already know the compression is different, but is there anything else different?
Old Nov 17, 2002 | 09:39 PM
rudeboy's Avatar
the fuel injectors will mostlikely be larger on the DET
Old Nov 18, 2002 | 07:18 PM
kaos's Avatar
Why did you post in 2 forums? Some people here are not gonna like that
Old Nov 18, 2002 | 07:44 PM
spitz7985's Avatar
some people like ME
Old Nov 19, 2002 | 06:10 AM
Justin.b's Avatar
No, it wouldn't be worth it. There really aren't many turbo kits for the FWD SR floating around. To get all the parts you need, it's easier to just buy an SR front clip - especially since you will need the ECU and probably haness. You will also probably need a suitable transmission - I don't know of the bluebird got the SR20DET and FWD - or if all the turbo models were AWD.
Anyway, it will end up costing you more money and MUCH more time to piece together an SR20DET than to buy a complete motor.
-Justin
www.saltgod.org
Old Nov 19, 2002 | 06:15 AM
Import Fanatix's Avatar
On the contrary, they are a lot of FWD SR turbo kits around, just go to any SE-R meet and 40% of the cars are turboed. YOu can also get a SR20DE engine for the S13, but that's just wasting time. Get the real deal Bad boy DET
Old Nov 19, 2002 | 06:41 AM
Justin.b's Avatar
From his post I though he was going to be looking for the OEM SR20DET parts - not aftermarket kits for the SR20DE.
Either way, my answer remains the same. The only way I'd consider an aftermarket turbo kit would be it if the car already had an SR running in it (Sentra/G20).
-Justin
Old Nov 19, 2002 | 08:44 PM
more opinions. not everyone looks into all the forums. so i put it in the 2 most likely spots.
but the main reason i was asking, was a friend of mine bought a turbo kit from a RWD s13 SR20DET motor, and he is planning on putting in a FWD SR20DE motor in his altima and put the RWD turbo kit on that motor. I wasn't too sure if it would work or not, but he wants to try. and i figured, if he ended up not making it work, i could get the turbo kit off him, and get the RWD SR20DE motor and swap mine with his kit. but once again, its a question, is it worth it. he already has a SE-R sentra tranny in his altima with the KA24DE motor.
TheAs1anKid
Jan 26, 2006 12:31 PM
logik05se
Jan 9, 2006 02:38 PM
dak2007
Nov 10, 2005 09:51 AM
JON
Southeast
Oct 26, 2003 09:28 AM
Diesel Clown
Feb 25, 2002 05:59 AM
