Do srd20det have speed govverns??
Old Jul 14, 2004 | 07:11 PM
89s13drifter's Avatar
An eprom is not reprogrammable unless you pull it out, put it under a uv light to erase it, and then reprogram it. You'll still need a daughterboard though. Ive gotten my sr past 130mph with my daughterboard and chips. Check out 925style.com for rom editor.
Old Jul 14, 2004 | 07:23 PM
Originally posted by doua
I don't know but, my sr could go 118mph. that is the max.
Thats the Gov. kicking in
Old Jul 14, 2004 | 08:12 PM
ArticDragon's Avatar
Yeah, you need to pull it out, erase it, then reprogram it. That's why it's call and EPROM. Kind of a pain, but eh, good if you know what you're doing and what to accomplish.
Old Aug 1, 2004 | 04:24 AM
Toastier's Avatar
my jdm klze powered mazda had the speed governer but for that you just cut the speed wire. If anyone wants to copy roms I have an eprom burner, send me a chip and I will do it.
Old Aug 1, 2004 | 07:24 AM
jonpowell's Avatar
Cut the wire that feeds the speed signal to the ECU, that is all you have to do. The only reason for that wire is to allow the speed governer to work, it has nothing to sdo with the eingine's drivability.
When I wire up the RB motors, I ALWAYS leave that wire off and I have gone 135MPH my RB25DET 240SX.
Old Aug 15, 2004 | 04:54 AM
StanBo's Avatar
Very good and you will still get a signal to your speedo?
Old Aug 15, 2004 | 06:54 AM
jonpowell's Avatar
Yeah, the signal from teh sensor gets split along the line to go to the speedo and then off to the ECU. The speed signal isnt like the tach signal that comes fromthe ECU. The only reason the speed signal goes to the ECU is for the governer to know when to kick in.
Old Aug 15, 2004 | 02:35 PM
StanBo's Avatar
Ok so that wire is going in the garbage. Thank you very much. New Jersey's finest thank you as well.
Now they can pull me over for doing more than 115.
hahahahahhahaaa
Old Jan 8, 2006 | 07:11 PM
v8killa's Avatar
doesnt cutting that wire mess up your idle while your slowing down thats what i heard
i know a few people who run switches to make sure the car idles fun when slowing down but when speeding past 110 just flick the switch and no speed limiter? Is this true? THANKS
Old Jan 8, 2006 | 07:38 PM
Waynehead05's Avatar
i cut the yellow wire with green stripe and it still kicked in. i then cut the only other yellow wire with green stripe and nothing changed.
which wire is it? (BTW i connected them back.)
Old Jan 9, 2006 | 01:32 AM
  #26
I cut one of muy wires, pin 32 I believe, Ill make sure later in the day once the light is out. But yeah, speed limiter is gone after cutting that wire AND taking out the 5th gear sensor. Ive managed to hit 6k in 5th gear
Old Jan 9, 2006 | 01:42 PM
  #27
Nismo241's Avatar
Originally posted by UndecidedPsi
Actually guys, I believe the "speed govenor" you speak of is because you are running your SR speed sensor. You are supposed to swap out your SR ss for the KA ss. What it does it tricks your ecu into thinking that you are always in 4th gear so there's no speed cut in 5th gear...or something to that nature. If you experienceing a speed cut, then there's probaly something else going on.
Thats incorrect, I've always used DOHC speed sensors when swapping SR's and always had a rev cut, the ECU is still getting the speed signal, you need to cut the wire that feeds it to the ECU, I used to have a vid online that showed an SR with DOHC speed sensor hitting governor, but it took up too much space.
On another note, jon powell, I've heard that works as well, I haven't tried it with the SR or any type of RB but I did quite a few years back on my SOHC and it would crap out around 3-4K in every gear (I'm also sure it was the correct wire)
Old Jan 26, 2006 | 09:02 PM
  #28
srtwenty240's Avatar
swapping the ss in my car definitely took that away... 140MPH vs. BMW M3 and 143MPH vs. '06 Subaru STI
Old Jan 28, 2006 | 05:22 PM
  #29
nsn240's Avatar
yup... at 115, get a tuned ecu or cut the wires
Old Jan 8, 2008 | 03:44 PM
  #30
hockeystar_27's Avatar
yea my sr cuts out at 118 also. but i have a ka speed sensor and it still does it.i heard u could cut a wire from the ecu, but i havent tried it tho.
