droppin a 351 windor in my hatch
Old May 30, 2007 | 10:09 PM
jturbo06's Avatar
and ideas on a tranny? i should be gettin the motor this weekend and im probaly gonna go with a c4 for now. lemme know what u think
Old Jun 6, 2007 | 05:34 AM
OutToWinPAHC's Avatar
Im not a ford g uy, im a chevy guy.... I have a LS6 and a TH350 in my S13 hatch. The C4 and the TH350 are very similar. I would ask what you plan to do wit the car first.
Mine is a fun street cat thats going to spend most of its life at shows. But in the same respect, able to run 10's at the track. Im using a Cusco 1.5way rear differential, and the trans is build with a hard shiftkit B&M, and a B&M 2800 stall converter.
If it was a drift car I would have used a T56, or even a T5, but I rather run, not slide. But if you just want a fun project, use a C4. You can get a C4/TH350 build ***** to the wall for a good price.
Old Jun 6, 2007 | 01:13 PM
jturbo06's Avatar
actualy i found a better deal on a chevy 350 and a 350 turbo trans. i'd like to turbo it but i only want around 500 hp. any tips are helpful
Old Jun 6, 2007 | 01:49 PM
Turbos are not going to work. Iv been looking at mine trying to figure out where to put them, and its not an option for me. It could be done, but it would be too tight. They would have to be mounted under the car. I just priced an ATI procharger, I called them direct becaus eI dont need an entire kit because its not a f-body or vette. Im attempting to lay 600 at the rear wheels.
Windsor would be sweet
but you would probablly have more $ left over if you just got the 350
Old Jun 6, 2007 | 02:58 PM
jturbo06's Avatar
well i was plannin oh havin the turbos stickin outta the hood or put em up where the batterie goes on each side. as for the 351w i found one rebuild wit a trans for 400 bucks but then i found my chevy 350 for 200 and a 350turbo trans for 35 bucks.that vett engine is sick. does it have the same mountin points as the 350? if it does what dod you do to make it fit?
Old Jun 6, 2007 | 03:06 PM
No the different generation small blocks have different motor mounts. I had to get it all fabbed up. Theres is a company who sells kits, but they notch the crossmember to make the oil pan clear. Which is very wrong because the S13 chassis cant take high torque as it is. The origional crossmember was beefed up and fabbed with the LSX motor mounts. This used to be a rear sump engine, but it was converted to a front sump. The GTO uses a front sump so I got the oil pump and pan new for that model LS2. I also had frame mods made to the car. The v8 conversion kits they sell dont have these, they are just bolt on kits without any reinforcment. I paid about 3000 for the engine, 1500 for the trans (its a maddog racing tranny), I supplied all the parts I knew I would need and the car to a Nissan racing shop, and they did the swap. 7800 bucks parts and labor, plus the 6000 in parts I sent them.
Old Jun 8, 2007 | 05:40 AM
By the way, it sounds like your buying some really used and abused junk. Usually when you get a complete small block that cheap, it needs to be rebuilt. Your gonna spend a nice amount of time and money making this swap happen. You might want to buy something of better quality. As for the tranny, 35 bucks isn't bad, but get it rebuilt. You can drop that thing off almost anywhere and get it rebuilt for 400 bucks.
How much are looking to spend on a swap?
Old Jun 8, 2007 | 06:21 AM
cracka Matt's Avatar
if really set on turbo, like said prolly end up under the car. but i know a guy back in ga with late model 4th gen ss camaro running one of those rear mount turbo kits and has had great results with it. I assumed there would be lag like a **** but he says there isnt. might be something to look into if you really want to turbo.
OutToWinPAHC, love the setup. hows the differential holding up? is there a shift in the center of gravity in the car?
Old Jun 8, 2007 | 10:25 AM
jturbo06's Avatar
the motor does need rebuild but im ok with that, i want to get a 383 stroker in there and im not realy woried about what its gonna cost cuz its just a project. would just raisin the comp to like 11-1 wit heads cams and all that crap get me the 500 im lookin for?
Old Jun 8, 2007 | 10:58 AM
Old Jun 8, 2007 | 07:06 PM
beat me to it but a rear mount turbo is an option for an engine than takes up most of the engine bay.
check out this link
http://www.chevyhiperformance.com/te...mounted_turbo/
Old Jun 8, 2007 | 08:27 PM
jturbo06's Avatar
ive seen those rear mounts befor. they sound evil but i dont think that would work ive already got my exhaust set up and its dumping out of the rear quarter panles between the door and rear tire
Old Jun 11, 2007 | 07:55 PM
Durdan's Avatar
**** rear mount turbos.
and yes, use a C4 on the windsor, but expect to service it often. you can use a C6, but they rob too much power. i loved my TCI built C4, but not good for highway use thats for sure considering theyre a 3 speed.
tonyfizzle
Aug 16, 2006 07:22 PM
tonyfizzle
Jul 21, 2006 05:39 PM
s13drag
Jun 13, 2006 01:00 PM
wills90
Jul 25, 2005 05:24 AM
Romeyo07
Oct 13, 2003 08:37 AM
