E To D Info On Swap S13 Help.......
I NEED ALL INFO ON HOW TO REPLACE A KA24E MTR W/ A KA24DE. INFO SUCH AS TORQUE SPECS ? WUT 2 DO A BOUT CUT WIRING HARNESS ON THE DE MTR? MTR MOUNTS ................ NEED INFO ASAP
THANKS
TIM
THANKS
TIM
if it's a s13 de the wiring is only 6 wires under the dash remove the glove box and there is a whit plug. you will need a s13 single cam plug on the tip of the sohc harness. snip it and snip the s13 dohc plug in the same location it is brown.
the wires are all color for color. so cut the brown clip off and the white one both from the engine harness and rewire color for color. then it will be plug and play.
everything else is strait forward except gota mod the power steering. get the resovoir and a dohc throttle cable aswell.
