Early stages of an Sr swap
Old Nov 21, 2005 | 07:46 PM
Legends702's Avatar
I have just a quick question before i start an SR swap, i am in the early stages but i am going to do suspension and brakes first, is any of this going to affect to swap (ie. am i going to have to go back and replace any of these or use different parts then i would now.) i was going to go 4 lug slotted and drilled rotors and KEi office coilovers, thanks for the input in advance.
Old Nov 21, 2005 | 07:48 PM
your engine has nothing to do with your suspension or brakes besides being able to handle the bit of extra power
Old Nov 21, 2005 | 08:02 PM
Legends702's Avatar
I just thought i'd ask before i started the work, Im new to the swap but i just wanted to make sure you didnt need new axles hubs or anything like that. cause the worse thing to do is go back to something you've already done =/
Old Nov 21, 2005 | 08:10 PM
nsn240's Avatar
the aluminum block sr is about ~100 (high) pounds lighter than the ka...brakes are a good idea though
Old Nov 21, 2005 | 08:14 PM
Legends702's Avatar
thanks nsn.
Old Nov 21, 2005 | 09:59 PM
Random's Avatar
brakes are always a good idea for any upgrade but make sure you go with quality parts. For ex. go with brembo slotted roters and maybe a project mu pads. It's only about $100 more overall but it will be alot cheaper in the long run. trust me, it will be worth it.
Old Nov 22, 2005 | 02:39 AM
Legends702's Avatar
ok cool random, could you direct me to where i can get brembro slotted and xdrilled. also the pads to, going to start the work as soon as i sell the fcrx7. i think im going to need to find an lsd for the car also.
Old Nov 22, 2005 | 11:40 AM
Levi SPL S14's Avatar
use google to find anything you need.
Old Nov 25, 2005 | 08:29 PM
birgir185's Avatar
search and you will find http://www.club240.com/forums/showth...threadid=27563
Old Nov 26, 2005 | 12:06 AM
Waynehead05's Avatar
FYI slotted are better than alotted and cross drilled or dimple or anything else out there. 93% contact and no brake fade when paired with DOT 4 or 5 brake fluid.
Bumnah
Mar 28, 2008 09:13 AM
crazyblue
West Coast/Hawaii
Feb 4, 2008 11:17 AM
JDMSIL80
Oct 23, 2005 09:15 AM
Xtreme240sx
Oct 14, 2004 09:26 AM
