Wiring in a safc ll
Old Nov 25, 2005 | 09:52 PM
nsn240's Avatar
Wiring in a safc ll
I've searched around for this... cant find an answer... what color is the wire that the safc (purple) knock sensor wire hooks up too? do you need that for the safc to function?
i'm hooking mine up tomorrow, just want to make sure. If anyone has any pictures of their's wired up, i'd appreciate seeing them
thanks
Old Nov 26, 2005 | 04:03 PM
2fast4y0u's Avatar
i ahve the diagram at home.... ill be beack at my house in 2 days. i will let you know.
jay
Old Nov 26, 2005 | 04:23 PM
nsn240's Avatar
thanks man... i tried to wire it up today, and nothing worked, no power at all...i think thats another problem, not the knock sensor wire
Old Nov 26, 2005 | 05:34 PM
Levi SPL S14's Avatar
SAFC-II Wiring Diagram for SR20DET
This information was tested to work on a red top SR20DET
It should work on the early black top as well.
SAFC-II Wire Color - ECU Pin # - ECU Wire Color - Function
White wire - ECU pin 16 - white wire - MAF Signal Input from MAF (You actually cut the ECU's wire in half)
Yellow wire - ECU pin 16 - white wire - MAF Signal Output to ECU*
Grey wire - pin 20 - white wire - TPS
Purple wire - pin 27 - white wire - Knock Sensor
Green wire - pin 3 - yellow/red wire - Tach Signal
Red wire - pin 47 - black/white wire - Power
Black wire - pin 39 - black wire - Ground (Further from ECU 1cm from brown SAFC wire)
Brown wire - pin 39 - black wire - Ground (closer to ECU 1cm from black SAFC wire)
Old Nov 26, 2005 | 11:47 PM
nsn240's Avatar
^that is exactly what i used... i dunno wtf is up with it. I wish there was a ps13 pinout diagram too, i just used the safc manual
Old Nov 27, 2005 | 05:34 PM
240sxsilvia's Avatar
im sending out my harness to wiringspecialties.com and they charge 50 to install it but sucks that you have you harness connected
jramosthe1st!
Sep 9, 2007 06:02 PM
boosted-alty
Feb 15, 2007 12:08 PM
TurboEvo
Jun 5, 2003 11:52 AM
SiNFuL
May 28, 2003 07:25 PM
LI S13 Blacktop
Apr 7, 2003 07:33 AM
