finished sr20 swap, but.
Old Nov 29, 2006 | 01:39 AM
RB26DETT_240sx's Avatar
I finally finished my sr20det motor swap today, and found out the motor is F'ed up, bottom end is completely shot, it is knocking on 3 cylinders if not all 4!
I got a video of it running and it revving, with one of my friends, you barely hear the knocking, but about 3/4 of the way through the video you hear the loud knock. It doesn't sound like much in the video, but it is 4 times as loud and worse.
I got this motor from JDM Engines Corp (www.jdmenginescorp.com), they are located in Richardson, Texas, near Dallas
Do NOT buy motors from this company.
For the people who is looking for a motor swap, research and find repabable companies, there are many out there, I got over my head, and wanted this motor as fast as i could get it, and got F'ed out of $2000.
There has been atleast 2 people i know that have had problems with their motors, one motor the cams were rusted stuck, the other motor, one of the cams was broken in 2 peices!
sucks to be me, I'm working on getting a longblock, and dropping that one in, I'll take pictures this time, the last time I didn't, and I wish I had.
But anyways, here is the video on youtube!
http://www.youtube.com/watch?v=0DpX9aV7IRg
Old Nov 29, 2006 | 10:28 PM
hmm, ive heard some good about them, my buddy got one from them and it ran great...they have like a 30day warranty or something dont they?
Old Nov 30, 2006 | 07:30 PM
they only gave me 15 day start up warranty, and that was just for the tranny, and motor, and nothing else.
but, I bought the motor in may, and had it turning on, but not on the road (explaination below) within 5 days, and it worked then.
I had to get the money for the fmic kit, exhaust, radiator, etc, I've been having money problems in the last few months, and didn't get it on the road the other day to test it.
It ran fine for about 5-10 minutes on the road, we didn't hotrod it around, just got it in to 2nd gear at 30 mph, and then we parked it for about 1 1/2 to 2 hours, then came back to run it again for another friend, and it was knocking like crazy, in 3 if not all 4 cylinders.
I've got a friend calling a few places for a long block to replace it.
after 6 months of work on it, (due to various reasons) I get it on the road and it starts knocking, just my luck!
This time around, I'll take pictures of the swap, and everthing, and make a thread about it, unlike the last swap!
Old Nov 30, 2006 | 07:31 PM
Old Dec 1, 2006 | 02:11 PM
trevr's Avatar
whoa, that is a kick in the nuts.
Its hard to take advantage of the 30 day warranty when you're buying parts in between paychecks and finding time to turn bolts between work and school schedules.
Like you, I bought my motor back in July, and other than seeing it pass the compression test I have no idea if it will even turn over. I hope in the end it will be worth it, cause the experience you shared scares the hell out of me. Only time will tell... Best of luck.
Old Dec 1, 2006 | 09:14 PM
you probably have already thought of this, but i'll list it for you anyways, I had to change all this out before running the motor, they were all bad.
change: (all will work with a 1993 sentra 2 liter fwd sr20)
*thermostat
*water temp sender (its near the block under the intake manifold, it has a single prong connector on it.)
*water thermostat gaskets (both sides)
if you don't know where this water temp sender is, look at this picture.
Water Temp Sender Location
Old Dec 2, 2006 | 11:02 AM
trevr's Avatar
thanks for that heads up, i appreciate it.
i'm doing the ca18det swap, i've already considered the thermostat, i will definitely look at the other parts.
Old Dec 2, 2006 | 11:25 PM
good luck on the swap, hope you get it running and not have problems like it did!
emoximuu
Dec 15, 2005 03:10 PM
bonomo
Sep 2, 2005 12:37 AM
zeroGripS13
Aug 5, 2005 09:12 PM
anubis
Feb 24, 2005 12:08 PM
s240r
Dec 22, 2003 11:23 PM
