Guage problems
Old Jul 9, 2004 | 03:57 PM
carcrazy1717's Avatar
Question Guage problems
Hey guys,
I have a 89 240 SE with a 95 KA in it. My problem is with the gauge cluster. When i picked it up the fuel and Temp guage worked not the Speedo and Tach. The next day none of the guages worked. I replaced the guage cluter with one from a 94 but nothing is working still, Do I need to put a newer style connector on the dash harness? NE help I could get would be greatly appreciated. Also Can anyone tell what are the best plugs to run and how can i lean out my motor, (runs way to rich) I just replaced the spark plugs and there satrurated in carbon deposits?
THANKS AGAIN
Old Jul 15, 2004 | 09:35 AM
rkcarguy's Avatar
The speedo prolly doesn't work because you need to install the speed sensor from the old engine that came out of the car. The tach should work if you put the newer cluster in, if not you probably have some wiring problems with your swap, maybe the dash pug not spliced right.
Nickmerrone
Sep 15, 2009 09:37 AM
sw20fj40
Dec 23, 2005 07:37 AM
240SILV
Nov 23, 2005 12:35 PM
240riderr
Oct 14, 2004 11:18 PM
98S14
Oct 12, 2002 02:40 PM
