Help with rb25 components
Old May 3, 2006 | 04:10 PM
dosusx's Avatar
Hiya all, im looking to get a rb25 swapped in my 95 240sx and get it around 475-500whp, what will i need to achieve this? like engine management system, stage 3 clutch, large intercooler and such
Old May 3, 2006 | 05:21 PM
jonpowell's Avatar
475 to 500HP at the wheels, I suggest ECU, 750CC injectors, Power FC/AEM/Haltech/SDS, whatever your wallet can afford, GOOD Timing belt, you MAY want to look into pistons for safety also. That number is pushing the limits of reliability for a daily driver if you are pushing it all the time. I bet you get 300HP in an S14 and realize how much power it REALLY is and decide youa re good. These cars are REALLY light and that much juice is really effective in them. Walbro fuel pump, Nismo regulator and a nice gauge, big fat turbo, nice exhaust mani(NOT THE SSAUTOCHROME PIECE OF CRAP!), the intake manifold might need some work/replacement, throttle body, axles, LSD, ummm
I will post more later when I get a chance.
Old May 3, 2006 | 05:26 PM
dosusx's Avatar
Thanks for the info so far, also when I get the motor what should i change on it before they start the install, i guess ill start with a compression test and clean the whole motor
Old May 4, 2006 | 03:16 AM
jonpowell's Avatar
I require the following when I install a motor to avoid any problems:
Timing belt
Water pump
Thermostat
Drive belts
Filters (oil, fuel, air)
Fuel pump
Regulator
Inline gauge
Spark plugs
Clutch
Fluids
I also do some servicing to the motor th remove any possibility of oil sludge from the engine and any corrosion/blockages from the coolant lines/system.
I had my personal RB25 with one of the coolant lines to the turbo totally blocked off....had to drill it out!
Old May 4, 2006 | 03:36 AM
dosusx's Avatar
And the same parts change would go for the sr20det also?
whats the top speed on the sr20 and rb25 that you can go in the 240sx?
Old May 4, 2006 | 07:51 AM
drf1nstyl's Avatar
my sr20det topped out around 140 couldnt tell because of the spedometer, but thats with some mods, fuel pump, manifold,full exhaust,intercooler,boost controller, a tuned ecu, stock ecu its 115 i believe, do not kno about an rb25
Old May 6, 2006 | 08:21 AM
dosusx's Avatar
Would i need a stage 3 clutch? and new flywheel?
Old May 6, 2006 | 02:31 PM
jonpowell's Avatar
"Stage 3" is subjective term that varies between companies. You WILL need a clutch that can handle at least 500 ft/lbs of torqie, whether the manufacturer of your clutch calls that stage 3 or not is up for grabs, but you will need to upgrade the clutch.
Flywheel is not necessary.
partyb0y69
Feb 14, 2004 12:43 AM
CP Racing
Dec 16, 2003 07:07 AM
CP Racing
Nov 28, 2003 03:13 AM
CP Racing
Nov 27, 2003 09:17 AM
adavib
Jun 5, 2003 10:30 PM
