ka24e auto to manual
Okay,
I'm buying another ka24e for my 89 240sx, and it has an automatic tranny... I'm going to use my 5spd tranny, so what all will need to be changed on the engine for it to work with the manual tranny?
Just the flywheel, or is there other things?
your not converting your car?, right. There should be very little to change maybe the tranny harness, tourqe converter to clutch, pressure plate, and flywheel. That should be all, but if your asking if it can be done yes, not to difficult either. Good luck
right... my car is already a 5spd... I'm just pulling out the engine, and dropping this engine in, which used to have an auto tranny attached to it...should I already have all the parts needed from the engine that's in my car right now? i.e. clutch, flywheel, ect?
im not converting anything, why would I mess with the ecu? all i'm doing is taking my 89 240sx 5spd, and pulling the engine, and putting the same thing back in...just it used to be auto.
spoolin240
Apr 13, 2004 09:46 PM
