motor mount help
Old Nov 11, 2005 | 08:28 AM
lostcoast240's Avatar
motor mount help
alright my car shakes when I'm sitting at idle and I am assuming it's one or more of mymotor mounts. How difficult are they to change on a 90 240? my last car was a 87 corolla and a 88 mr2sc..both of there motor mounts were cake to change. Curious how easy it would be for a 240
Old Nov 11, 2005 | 08:44 AM
dak2007's Avatar
are you sure it's the motor mount
Old Nov 11, 2005 | 09:16 AM
no I'm not. If you have any other suggestions it might be it could help narrow things down
Old Nov 11, 2005 | 01:30 PM
naptime's Avatar
mine was shaking at one point. changed plugs and wires and it went away so give that a try
Old Nov 11, 2005 | 01:55 PM
dak2007's Avatar
well mine was shacking violently the other day. i heard a sound from under the valve cover. comes to find out two of the bolts holding my rocker arm down had vibrated loose. when it's running does it run pretty badly outside of the shacking? like poor throtle response.
Old Nov 11, 2005 | 03:55 PM
runs great when I'm moving...you can only notice the shake when I'm at a stop light or something. I just changed the plugs today...gonna change the wires next....
Old Nov 12, 2005 | 09:42 AM
dak2007's Avatar
i don't know what to tell you but i would take the valve cover off just to make sure you don't see anything shiny that would be hitting.
Old Nov 13, 2005 | 02:01 AM
JDMxDrift's Avatar
Its probably a combination of running rough and bad motor mounts. The car is 15 years old. i know my tranny mount is bad because when i drive on the freeway the shifter shakes violently with all the bumps.
JokeR902
Feb 3, 2009 02:05 PM
SnoopDoug762
Jun 13, 2007 08:53 AM
NJKnight
Aug 4, 2006 11:51 PM
jedimastereric
Jun 25, 2005 12:42 PM
Krea2nr
Jan 20, 2004 09:54 AM
