motor mount
Old Jul 11, 2006 | 11:12 AM
NJKnight's Avatar
motor mount
Motor mount what would be better inserts or motor mount it self and where can I get it guys I heard the well over 100 dollars is that true?
Old Jul 11, 2006 | 01:41 PM
Yes, usually over $100 to replace motor and tranny mounts. I don't think I've ever seen inserts for our cars like I have for FWD applications. There are several different brands, and different types. Also which type depends on if the car is a daily driver or if its all track or you don't mind cabin vibrations.
Old Jul 11, 2006 | 03:49 PM
NJKnight's Avatar
i don't mind cabin vibrations
Old Jul 12, 2006 | 12:59 AM
I'd probably get something like Nismo or something urethane. You said you don't mind cabin vibrations but if its going to be daily driven, solid mounts would probably bug you more than you think.
Old Jul 12, 2006 | 12:47 PM
Badazz_240's Avatar
Nismo FTW!!....... lmao
good choice tho... really
Old Jul 12, 2006 | 01:15 PM
barcode's Avatar
i would go nismo, thts what I plan on just to keep my motor from jacking around so much, it looks scary, i can see because i didnt have a hood for a while.
BTW what does FTW mean.....
Old Jul 12, 2006 | 01:19 PM
Badazz_240's Avatar
For The Win....
It's like... either sarcasm or actual enthusiasm... sometimes its hard to tell the difference
It's just that people push Nismo products too much because of the name, but in this case... yeah it's a great part
edit: If your motor is "jacking around so much" , you might need an engine damper too lmao... but im sure it's fine
Old Jul 12, 2006 | 01:21 PM
http://www.jgstools.com/turbo/index3.html they carry motor mounts as well.
Old Jul 12, 2006 | 01:30 PM
Badazz_240's Avatar
^^^ That site needs an update.... anyway moving on
www.splparts.com
Engine>Other engine parts>Nismo engine and tranny mounts
$218 for the set..... You could probably find them cheaper if you try hard enough
Check eBay if you want just the motor mounts.... like $175 ish shipped
Old Aug 4, 2006 | 10:34 PM
nissan SR20's Avatar
i went with the nismo motor mounts which are pretty much the best on the market i believe.... you can pick them up on ebay for a little under 200 if your lucky... peace
Old Aug 4, 2006 | 11:13 PM
Best, I dunno, depends on application. If you've only ever tried stock and Nismo, you can't say they are better than others.
Old Aug 4, 2006 | 11:51 PM
does anybody have experience with the jgs tools motor mounts? are the nismo ones worth the $30 more? which ones are stiffer?
JokeR902
Feb 3, 2009 02:05 PM
SnoopDoug762
Jun 13, 2007 08:53 AM
lostcoast240
Nov 13, 2005 02:01 AM
slideo12
Oct 19, 2005 06:29 PM
Import Fanatix
Sep 25, 2002 03:50 AM
