My swap begins , Need any advice you can offer!!
Im getting my S-14 front clip saturday , I will begin my swap on that day. I have a 95 240sx with the 98 headlight conversion, I put the LSD in it and the clip is next . ANY ADVICE BEOFRE I START on this project willl be thankfully accepted.
Take your time on the swap...dont rush anything. On the wiring espically, becareful on wut u do and stuff. And have fun
Cant wait till i start on my swap...i should probably be starting next weekend or so..im pretty close to buying a 240.
take your time and be very patient. oh and word of adive, try to get the tranny and the motor in as one piece it will make things easier, well I know that is true with KAs but I have never really looked at a SR closely.
Ok I pulled the motor and trand and wiring harness , The Clip came with a mandrel bent 3 inch down pipe ( sweeeeet)
The Motor is in decent shape. The clutch was like brand new.
Trans needs a shifter so im ordering a short throw.
Ok i pulled like 3 harnesses and man this looks complicated , I will be pulling the KA tonight and it will be fun .....
a few hints on the sr swap.
leave the isolaters on the mounts on the block. the cross member is sloted so it will slide in kinda easy.
and yes keep the motor and tranny as one, kinda duck dive it in.
remove the aiv stuff it wont fit, blocks the steering column.
do your heater hoses before the motor goes in. swapem from rhd to lhd.
take invetory of all the parts out of the clip make sure you got everything.
engine harness coilpacks,igniter chip,CAS, and so on.
a sr swap is one of the easiest swaps out. pretty straight forward. like he said just take your time.
get a good look at the clip before you strip it.
make notes if you need to.
dont mix up the 240 bolts with silvia bolts keep everything seperated.
so good luck if you need any advise or help hit me up. pm or something.
good luck!
good luck!
Ok so far so good , I have An idea of how to start now , Except what is the AIV stuff.
I will start the wring before the motor goes in obviously , Im think start by putting in the S14 Fuse block in the Engine comp and work from there , What do I need to use from the KA harness , and were should i mount the ECU. After wiring i will do hoses/Heater then the motor and trans and hook it all up then the radiator and fans and finally the intercooler , Can anyone recommend a good front mount without going crazy on price.
Well I took a break on the car for a while, But last night I put the motor and trans into the car. The harness is gonna be sent out .. Im sick of it, And i dont wanna do any harm too it. Well I will be installing the coilovers tonight. I have also installed the ST anti-sway bars. I will have pics off everything soon
