NEED HELP with my SR20!!!
Old Aug 18, 2005 | 07:51 PM
ps13drifter's Avatar
aight let me tell u guys the senerio.... i have a 89 240 coupe with a red top sr20det... worked fine for awhile but out of no where im haven idling issues... when i turn the car on it goes to normal (cold) idle witch is bout 1200 rpm then itll kreep up to 1500 then to 1900....the thing is when i drive her a lil and get on it itll idle back to normal..and before this problem the car would drop down to 500 rpm and idle like **** and i found out it was the air flow sensor cuz when i moved it while the car was on it would mess it up and make it run like ****...sooo i cleaned it and snapped it back together and now im haven the idle issue...oviously i planned on goin with a z32 air flow sensor in the future but do u guys think thats the problem??? if it is i would juss replace it with the z32 one...hopfully u guys can hel thankz in advance
Old Aug 19, 2005 | 03:17 AM
moved to "Engine Swaps"
Old Aug 19, 2005 | 10:59 PM
jbask's Avatar
If you put the z32 maf on will you need to retune the comp????
if not I'm gonna throw one on too
Old Aug 19, 2005 | 11:07 PM
Helghast's Avatar
putting the Z32 maf means you have to retune..or have a SAFC
Old Aug 19, 2005 | 11:27 PM
Levi SPL S14's Avatar
sounds like a vaccum leak to me
Old Aug 19, 2005 | 11:47 PM
thats wut i thought it was to a vacum leak...but would a vacum leak go back to normal after u drive it fo a lil??
Old Aug 20, 2005 | 01:31 AM
hmm cars i have driven have gone back to normal others havent.
swap mafs with another and try that.
and check yoru timing.
Old Aug 22, 2005 | 06:57 AM
nowigot9's Avatar
Try unplugung the TPS thes sound liek the start to my problems if it cleans up replace it. If it stays the same then its not the TPS and that is one less thing you have to worry about.
Old Aug 22, 2005 | 10:50 PM
thankz guys, ill try the TPS and see wut happens...hopfully itll work otherwise like u said 1 thing off the list....
Gary43
Apr 21, 2004 04:58 PM
slidingsideways
Jan 19, 2004 11:46 PM
mr.nismo
Jan 12, 2004 02:03 PM
sonic16
Jul 21, 2003 05:11 PM
s15con240
Apr 15, 2003 05:49 PM
