Now what?
Old Dec 11, 2008 | 03:16 PM
stetay2233's Avatar
Now what?
i'm new to the forum. i have a 1998 Nissan 240sx auto. I'm looking into doing an sr20det swap with my father (engine, trans etc) i have found a front clip for $3,000 but i have questions.
1. Can i still have a/c and if so do I need to buy a new one or can I use the one from my ka24de?
2. With the front clip, what else do you suggest I get/need to get to make it all work?
3. Will my auto gauges work w/the swap?
I know these are a lot of ?'s and I'm gonna get yelled at to use the search feature but I've been searching for a week now and can't find anything (yes I'm a noob) just wanna get the "father son project" underway. Thanx guys.
the front clip:
http://extremejdm.com/clip_nissan_s14.htm
Old Dec 11, 2008 | 03:47 PM
shaban's Avatar
1. AC you can have it on the SR, you just need the KA bracket modified to work on it (IIRC)
2. You don't need much to make an SR work. But if your not planning on getting a bigger turbo/buying a boost controller, I suggest seeing if it has the factory boost solenoid. That will raise the boost up from the factory 7psi to 11psi.
3. and yes, your gauges will work fine, if you're sending your wiring harness out to get done, make sure you tell them it's an auto to manual swap. I suggest using Durdan from this forum, he does excellent work!
Old Dec 11, 2008 | 04:04 PM
stetay2233's Avatar
Thanx a lot man. we're just planning on doing he swap but down the line just couple little things. looking for an exhaust ride now the turbo manifold downpipe etc., many something else suggestion. not looki for a huge horsepower monster. 250-350 maybe. no clue yet
Old Dec 11, 2008 | 11:53 PM
positron's Avatar
If you're not going to rebuild anything then just do the basic maintenance that everyone does before the swap like some gaskets and whatnot.
Old Dec 12, 2008 | 02:16 PM
stetay2233's Avatar
yah i was thinking about that. should i get a new fuel pump? is there anything thing you guys think i should do to my car before the swap that most people do? any electronics and gauges that are recommended i have?
Old Dec 12, 2008 | 02:25 PM
http://www.srownersclub.com/faq/index.asp
Old Dec 12, 2008 | 02:53 PM
stetay2233's Avatar
great thanx alot man.
Old Dec 16, 2008 | 03:27 PM
stetay2233's Avatar
so I'm planning on getting the front clip mentioned in my first post. i am also going to get a fmic, megan exhaust, manifold, downpipe, hks air filter kit, boost and oil pressure gauges.
what else should i get?
Old Dec 16, 2008 | 04:00 PM
shaban's Avatar
you're going to need everything to do the auto/5sp swap
https://www.s-chassis.com/forums/how-tos-installations-48/auto-manual-writeup-5-speed-swap-33633/
Old Dec 16, 2008 | 04:56 PM
yea use that thread.. everything you need
Old Dec 16, 2008 | 05:21 PM
USMCDrifter's Avatar
SR20DET ULTRA HEAD EXPLOSION! Candle Jack crazy take m . . . . .
-Dave
Old Dec 26, 2008 | 04:22 AM
japanesenut's Avatar
the front clip:
check these guys out this is just a swap not a clip but and ive talked to them before about a s-14 notch top pretty good people and will provide pics and a compression test of motor your getting and free shipping on motor sets . http://www.japanesestarmotor.com/eng...hp?EngineID=45 and pick up the auto to manual conversion from a junk yard
Sircnay
Jul 13, 2003 07:37 PM
kboonhower
Jun 10, 2003 09:41 AM
leiferik1
May 12, 2003 05:44 PM
PROJECT240SX
May 2, 2003 10:57 AM
Ryan
Feb 11, 2002 03:29 PM
