Bought my car today now makes a wierd noise
Old May 31, 2003 | 07:41 PM
kboonhower's Avatar
Angry Bought my car today now makes a wierd noise
I just bought my 240 today and i love it except that when you back up and stop it makes a thud noise i thought it was the exhaust but i checked it and nothing touches. Where is the noise from????
Old Jun 1, 2003 | 09:01 AM
Strizzy's Avatar
does it make it as you are putting the shifter into reverse, if so could be the tranny...
Old Jun 1, 2003 | 04:45 PM
kboonhower's Avatar
No it just makes the noise after you let start stopping right after you back up Could it be the universal joints in the driveshaft?
Old Jun 2, 2003 | 09:47 AM
S13Nissan240SX's Avatar
Does it sound or feel like it's coming from the brakes? Mine grumble occasionally while I'm in reverse.
Best wishes,
Matt
Old Jun 2, 2003 | 11:09 AM
spitz7985's Avatar
mine too, its a sticking caliper
Old Jun 3, 2003 | 04:48 AM
kboonhower's Avatar
thanks, is there anyway i can fix this? it also does it when i shift gears real hard going forward
Old Jun 3, 2003 | 11:55 AM
Spec240sx's Avatar
Take a Close look at the mounting rubbers. You MAY find that
you have to replace the trailing arm rubber.
Jacking the car to open the well is the Best way to view this.
Just an idea
Old Jun 3, 2003 | 12:00 PM
Damicci's Avatar
Mines does it too but only when i step on the brake kinda quickly like a jerky stop.......i dunno but it only happens in reverse.
Old Jun 3, 2003 | 08:35 PM
kboonhower's Avatar
Thanks
thanks ill look at them but how do i tell if they are bad?? This is going to be my weekend project. I hope i get it fixed its my only complaint about my new ride
Old Jun 4, 2003 | 12:43 PM
I wouldn't really classify this as a complaint or even a problem. It's just one of those things you have to deal with when you have an older car. Mine makes that grumbing sound but it stops fine. Thats why I've never bothered to worry about it. If you really want to fix it though, I'd just replace the rubber as was suggested. Either way, if that doesn't work, you'll be closer to finding the real problem. Should be pretty easy to find.
Good luck,
Matt
Old Jun 8, 2003 | 03:52 PM
kboonhower's Avatar
Found the problem
The noise is coming from my differetial took it to a shop and they said i have less then a month on it so i need to find one does any one know where? i dont care if its new used or rebuilt. Thanks
Old Jun 9, 2003 | 11:51 AM
Damicci's Avatar
Looks i may need to upgrade to LSD.
Old Jun 10, 2003 | 09:41 AM
Spec240sx's Avatar
Re: Found the problem
www.car-parts.com
and look in your state.. You should find all kinds of Pumpkins..
LA_phantom_240
May 16, 2006 07:58 PM
90sx
May 5, 2006 05:54 AM
Driftingkid101
Jun 6, 2005 04:20 PM
ArticDragon
Jul 11, 2004 09:19 AM
bradltl
Feb 20, 2004 01:34 PM
