oil in intake?
Old Sep 29, 2005 | 11:43 PM
STEARNZY's Avatar
oil in intake?
ok i got my engine running and it is goin good but i got alot of oil in my intake just past the turbo so im wondering if this would be a cracked turbo or just a gasket
Old Oct 2, 2005 | 01:43 PM
thekman's Avatar
could be both take a look
Old Oct 5, 2005 | 06:43 PM
zeroGripS13's Avatar
sounds like turbo seals.. if the turbos got some age on it, its probably just normal wear.. wipe it all clean and check again in a week if its just a small amount of oil.. you should be ok for a while.. while ur at it check the turbo for shaft play
Old Oct 6, 2005 | 09:37 AM
nsn240's Avatar
sounds like either the turbo oil seals^^ or the vaccuum lines... you may need an oil catch can, whenever you arent boosting there's a vaccuum that pulls oil from the valve cover into your intake
VW_unfortunatly
Jan 13, 2007 12:42 PM
SC240sx96
Aug 11, 2006 01:23 AM
Mattyg2
Dec 20, 2004 02:58 PM
cticknor666
Oct 22, 2004 03:24 AM
