Please HELP Turbo Noise
Old Jul 25, 2005 | 06:41 PM
nowigot9's Avatar
I have had my SR20 Swap for about a month now and two days after i did it i started to here the really loud high pitch scream when ever i was in boost. Some of my friends told me it was the turbo so just this past weekend i purchased one used from a guy that was upgrading his. The new turbo had Minimum shaft play and spun freely it was pretty much in really good condition. Well i installed it yesturday got the car back on the road and to my suprise the scream was still there.
Today i looked at the turbo and it in good condition as well i even had a few other people looked at it and they told me the same thing.
I still have this Really Loud High Pitch Scream when im in boost. the car boost fine and does not smoke at all its runing stock boost right now.
Does anyone have any idea what could be the problem with my car?
PLEASE help.
Old Jul 25, 2005 | 06:46 PM
2fast4y0u's Avatar
dude thats the sounds of the turbo...mine does it to
Old Jul 25, 2005 | 06:47 PM
nowigot9's Avatar
Is that a bad thing or it just going to happen because it is really loud.
Old Jul 25, 2005 | 06:58 PM
2fast4y0u's Avatar
do you have an intake on it....like a short ram i guess you would call it. or is the factory air box
Old Jul 26, 2005 | 06:10 AM
nowigot9's Avatar
i have an HKS intake and an HKS SSBOV
Old Jul 26, 2005 | 09:47 AM
Cloud7659's Avatar
My Rx7 used to whine like crazy! I guess you just have to be able to tell wether its broken or running REALLY good.
Old Jul 26, 2005 | 10:38 AM
nowigot9's Avatar
Well the motor boosts fine with no problem. I do have some kind of fuel problem because it runs really rich and i think i have a small vacume leek
Old Jul 26, 2005 | 05:12 PM
Levi SPL S14's Avatar
do a leak down test
Old Jul 27, 2005 | 04:46 PM
Catharsis's Avatar
its blown
Old Jul 27, 2005 | 07:10 PM
nowigot9's Avatar
whats blown? the turbo? From what i here and understand if it was blown it would would not boost. but i may be wrong. Someone else told me because the motor sounds like it has a miss and its running rich blowing out black smoke that i have a boost leak. Im not sure.
Old Jul 27, 2005 | 10:18 PM
Catharsis's Avatar
if it is making a high pitch screetching and not a normal boost sound it is blown
Old Jul 30, 2005 | 06:15 AM
s14ilvia's Avatar
Did you use a new gasket from the exhaust manifold to turbo when you dropped the new one in? If not, then check that. My SR used to make a similar noise and it was because that gasket was blown.
Old Jul 30, 2005 | 08:21 AM
nowigot9's Avatar
it acts as if it has a boost leak. it runs rich and everything. Ive checked all the couplers the intercooler and all the gaskets.
Old Jul 30, 2005 | 11:41 AM
2fast4y0u's Avatar
if it had a boost leak it definetly will run like poop
i just replaced the gasket in between the turbo and the turbo manifold and mine still makes that niose. my turbo also boost just fine and very quick. my car pulls very hard, my tubo is definetly not blown.
like Catharsis said, it could be blown...or its just the niose ur turbo makes
Old Jul 30, 2005 | 12:07 PM
Nismo241's Avatar
Originally posted by LandHo_S13
do a leak down test
But why? He's asking about his turbo not motor. A leak down test does nothing but tell you wether or not compression is leaking, and from where.
