power steering pump + A/C delete
Old Oct 14, 2005 | 05:11 AM
GotSmoke?'s Avatar
has anyone removed both the power steering pump and the A/C pump? If so what belt do you use now?
Edit: Duh this is for an SR20DET
Old Oct 14, 2005 | 09:54 AM
I'm with Stupid's Avatar
I don't get it... Is this a joke?
Old Oct 14, 2005 | 06:47 PM
nsn240's Avatar
uh... #1 why remove your ac? it'll say you like 10 pounds (literally) and just make you hot... unless you are building a drag car, there is not point in tossing it... wtf are you talking about w/ the ps pump, you just take the belt and pump off...
Old Oct 15, 2005 | 08:17 AM
Gearhead_42's Avatar
Instead of saying something useless...
The SR uses three separate belts for alt, ac and ps... remove any two and the third one isn't affected...
Old Oct 16, 2005 | 03:01 PM
toycar's Avatar
if u want to disable it just pull the belt off. if u take any of those lines off of the pump ur gonna be sorry
Old Oct 17, 2005 | 02:33 PM
Levi SPL S14's Avatar
why remove your PS?
thats stupid.
Old Oct 17, 2005 | 02:50 PM
GotSmoke?'s Avatar
Ok basically there is no forum anywhere with the kind of good info that is here, that is specifically geared toward my project.
I am not swapping into a 240sx. I am swapping into a car that doesn't have (or need) power steering.
That is also part of the reason for my stupid question(s) because I do not even have my engine yet. I have my Transmission Adaptor, custom flywheel, and clutch (and the car)
I am just trying to limit the amount of time I will spend scratching my head once I do get the engine shipped.
The engine is approx 60-120 lbs (it is replacing a 200lb engine, I have no exact number on how much an SR20DET weighs but I assume less than 365lbs of a VG) heavier than the one it is replacing, removing (hopefully 20lbs+) will be a big start in keeping my car balanced without requiring even more reworking on my suspension.
I am not new to swaps, I am just new to nissan.
Old Oct 17, 2005 | 03:18 PM
If you're worried about weight don't forget the stock exhaust manifold and o2 housing weigh a good amount.
Old Oct 17, 2005 | 04:17 PM
GotSmoke?'s Avatar
awesome, thanks
tegg_gsr
May 16, 2004 07:23 PM
79280
Jan 29, 2004 12:41 AM
Topless240
Apr 23, 2003 07:05 PM
cjm93240sx
Apr 12, 2003 10:11 PM
cjm93240sx
Apr 12, 2003 09:29 AM
