Problem with sr20det swap?
Old Mar 20, 2004 | 11:34 PM
RBpwrd240SX's Avatar
Question Problem with sr20det swap?
I just installed a blacktop S13 motor into a '92 240sx hatch and now when I start it it will idle very rough and then will cut off. It will rev up a little but not smooth. The CAS is set properly. Anybody have any ideas? Thanks for any help.
Old Mar 21, 2004 | 09:08 AM
Ricky240sx's Avatar
How long does it stays on for?
Old Mar 21, 2004 | 01:52 PM
It will stay running if you give it some throttle but it doesnt idle. It seems like it might be a fuel problem. I am going to check to see if I am getting enough fuel pressure.
Old Mar 24, 2004 | 08:06 PM
Ricky240sx's Avatar
Ok keep me posted
Old Apr 4, 2004 | 07:37 PM
I found the problem! I have the wrong MAFS. I bought the car with a blacktop sr20det and the kid couldn't finish the swap so I have been piecing the car together. I thought the right MAFS was with it but it turns out that it was the stock '92 ka24de MAFS and I am under the impression that it will not work. The car idles fine with the MAFS unplugged but as soon as I plug in the '92 ka one it idles bad. I am looking for an '89-90 ka or sr MAFS so hopefully that will fix it.
Old Apr 5, 2004 | 11:50 AM
89s13drifter's Avatar
If you have the money nows probably a good time to get a z32 maf, bigger injectors, and ecu.
dd240sxdd
Nov 19, 2006 10:01 PM
vortxxe
Apr 29, 2006 05:22 AM
uvamosk
Aug 12, 2005 07:31 PM
JeffSchmitt
Mar 5, 2004 05:28 AM
Yusuke
Jun 9, 2003 09:19 AM
