RB20 Finally boosting-almost...
Old Sep 29, 2004 | 12:20 AM
rkcarguy's Avatar
I got the boost problem fixed finally fixed-sort of. The exhaust wheel was clearanced too close and was rubbing on the exhuast housing in my turbo. I die ground a little out of it and it finally boosted, but then got hot and still rubs, so I have to grind some more material out of it. Sure went like hell tho boosted to about 10PSI and sat me in the seat hard!
Old Sep 29, 2004 | 01:13 AM
Jedi Mind Gamez's Avatar
congrats....
off topic a lil....wut is stock psi on a rb20.... i alwayz thought it was 6-7 but then xjon said it was round 10 in a pervious thread and rk said it just boosted to 10
Old Sep 29, 2004 | 02:50 AM
iroc07's Avatar
I thought mine was only going up to about 8, but I dont have the gauge in yet so I was just guessing by sounds feel and comparing to other turbo cars I have driven. Mine gets up to full boost super quick and just stays there. I cant wait to see what it does with a boost controller and a gauge to monitor it with.
RK good to hear its up and running/boosting
any more info on the cold start prob?
Old Sep 29, 2004 | 03:26 AM
ruthless_S13's Avatar
The stock boost for an rb20 is 10psi.
Old Sep 29, 2004 | 05:05 AM
iroc07's Avatar
I didnt even remember the stock gauge cluster going up that high. where did you get your info ruthless? not saying your wrong at all, I just didnt remember and would like to check and make sure I am not wrong on anything else.
Old Sep 29, 2004 | 06:05 AM
It's what Jon told me. I thought it was only 7psi and when I could get only 10 psi at the lowest setting I was trying to figure out why. With my boost controller turned off it boost at 10psi.
Old Sep 29, 2004 | 08:53 AM
TWAN's Avatar
Keep us updated. I thought it was 7 also. does it have the stock internal wastegate or has it been converted to external?
Old Sep 29, 2004 | 09:29 AM
ArticDragon's Avatar
Where's the pics oif your car man?!
Old Sep 29, 2004 | 09:48 AM
I've alsways heard stock boost on a RB20 is 10PSI.
Old Sep 29, 2004 | 10:03 AM
jonpowell's Avatar
Stock boost on RB20 is 10PSI..the stock gauges dont read in PSI they read in MM-Hg and the 7(00) on there is 13.5 PSI.
The RB25 has a 2 stage boost cut. under 550RPM is 5PSI after is 7PSI.
The R32 RB26 boosts at 10PSI and I believe the R33 RB26 is 11PSI
Old Sep 29, 2004 | 10:53 AM
iroc07's Avatar
thats why I saw 7. haha, once again the mysteries explained!!!
Old Sep 29, 2004 | 06:34 PM
rkcarguy's Avatar
yeah I'm dfinately boosting about 10PSI. Took it out for a run today, still a little interference in the turbo, going to have to grind one more time. I'm going to have to restrict the oil flow the turbo fills up and oil leaks into the exhaust housing so it smokes once the oil gets warm and thins out. The motor is tight- I took out the plugs and they are CLEAN and I'm not getting any detonation or overheating. Nice to have a motor that was actually meant to be turbo.
Old Oct 1, 2004 | 06:15 AM
srslider's Avatar
congrats man! good luck with getting that turbo finished up
HKST04Z
Aug 26, 2007 03:29 PM
RBfastback
RB
Aug 10, 2007 09:50 PM
bboy953
Jul 1, 2006 10:58 PM
rkcarguy
Oct 10, 2004 01:47 AM
Romeyo07
Nov 15, 2003 09:20 PM
