rb20det transmission
true. but isn't the R34 GT-R (or BNR34 if u wanna get technical
) the first and only Skyline/GT-R to feature a 6 spd tranny (exluding all other R34 GT-R's; V Spec, M Spec...)?
I thought ALL GTR's were 6speed AWD.......not sure either
Originally posted by Spec_v5150
Hmmmmmmmm
Hmmmmmmmm
http://www.j-garage.com/2110.htm
http://www1.tcue.ac.jp/home1/english...lass25/101135/
http://www.ultimatecarpage.com/frame...car.mv&num=395
http://homepages.tig.com.au/~robs/kevspage9.htm
http://www.jbskyline.net/R34/GTR/index2.php
while i can't exactly vouch for the credibility of the sources listed, i don't believe that they all copied info from one another. however, until i can see factual info directly from Nissan, i'll only regard this as a "very strong possibility", but not set-in-stone-fact...
there is a site that tells you how to mack a rb30 from the rb26 and I think Rb25. I don't see how this is possible but I also think you can make one from the RB20. I forget what site this is but I will get back to you as soon as I find out. The site also lists all the other RB engines in it and tells compression etc. Maybe it will have transmission specs.
http://www.meggala.com/nissanrb3css.htm
maybe that's what u were talking about, but i couldn't be sure. anyway, hope it helps!
gmckey
Apr 24, 2003 06:59 PM
anttoni
Jan 9, 2003 06:33 PM
