rb25det s14 wiring or fuse problem!!!HELP!!!
Old Aug 28, 2004 | 09:06 PM
s14 rb25det's Avatar
I just got a r33 rb25det swapped into my auto 95 240. When i was driving it home from the shop i got the swap done at, i noticed that the engine was starting to bog down once i started using the windshield wipers and headlights. i had to recharge the battery 3 times just to drive an hour. at first i thought that it was the alternator,but i took the alternator off and got it tested at advanced auto parts. the alternator ended up being fine. Does anyone know what the problem would be or could be. If you could respond ASAP, i would greatly appreciate it. Thanks
Old Aug 29, 2004 | 07:34 AM
jonpowell's Avatar
The alternator wiring is probably all farked up....Ask the installers if they used the KA lower harness or the RB lower harness...
If its the RB its probably not wired correctly to charge the system.
alex_s817
Sep 17, 2009 05:52 PM
darook
Aug 13, 2005 05:42 PM
uvamosk
Aug 12, 2005 07:31 PM
Paul_Boz
Oct 1, 2003 10:26 PM
Jolt21
Sep 28, 2002 02:20 PM
