RB26...More problems...Fuel/electrical
First issue seems to be fuel related. I'll be driving along at a steady speed and the power will seem to dip down for a second then catch itself. Sometimes it is worse than others. At one point tonight it would hardly rev at all...it would just bog down and kind of gargle. This problem has also extended to the car's idle. It usually ideals fine but if you leave it alone for awhile it will die.
I have a walbro fuel pump and nismo fuel regulator that is set at about 30psi (I'll have to look again for exact psi). The tuning on the car is completely stock as far as I know....any Ideas?
Second issue is with the tail lights...a light burnt out the other day so I replaced it. Well the next day it burnt out again, the same light! Like WTF. Also, it seems to be blinking faster than normal in both the blinker indicater light and the actual blinker.
tay-fu300zxtt
Sep 9, 2010 07:22 AM
srnissanpower
Jul 6, 2006 07:19 AM
