red vs black
red vs black
I thought this question would be one that would have like 50 different threads when i typed it into the search bar, but i couldnt really find an answer. Well i probablky sound like a complete noob but my question is if there are any major differences between the sr20det redtop and blacktop besides the color of the valve cover
. But really is there? because when i looked at the specs it seem like it was almlost identical,, so how come the blacktop usually found to be a little more expensive?
Thanks!
. But really is there? because when i looked at the specs it seem like it was almlost identical,, so how come the blacktop usually found to be a little more expensive?Thanks!
http://www.drift-connection.com/sr20det-specs.php
no, power isn't the same, vtc + different turbo up the hp from 203 to 220.
REMEMBER: The hp didn't change between the red top and black top until the s14 model was made. There is a black top S13 model, and a black top S14 model. The S13 black top has the same power as the S13 red top, but the only difference is that it was newer.
you didn't search hard enough.
https://www.s-chassis.com/forums/engine-swaps-13/common-240-engine-38496/
its a sticky in the very thread you posted in
