Rotary powered RPS13
Old Jan 18, 2004 | 05:08 PM
niz_sport's Avatar
Might sound odd, but I was wondering if anyone has heard of anyone doing one successfully. I know I'd run into tons of problems with this setup on my 240, but it's not gonna be a daily driver anyways.
So here's how I figure it, it's a small compact engine that fits in almost any car it's put into. The problems I think I'd run into are engine mounts and different tranny and mounts. I'm going to bring up the question over to checkpoint performance in Rancho Cordova, mazda/rotary engine specialists.
So give me some input, possible links on the idea. I did a search on here I didn't get much.
-Bert
Old Jan 18, 2004 | 05:39 PM
A rotary would take more to maintain it...Id rather stay KA then go rotary
Old Jan 18, 2004 | 07:54 PM
niz_sport's Avatar
I would if I could, meaning, I don't have a KA in this thing... well I have the bottom end, with a hole in a piston. Maintaining it isn't a problem, rotary engines are notorious for reliabilty problems, but I figure if it's hardly on the road, it wouldn't really matter. It's more of those owning something odd that you don't see too often.
Old Jan 19, 2004 | 02:23 AM
Luv_piece's Avatar
Off hand I'm going to say that the tranny will be alittle shorter.
Old Jan 19, 2004 | 04:17 AM
Nismo241's Avatar
Tranny is normal size, the motor is short, it'd be a ver simple task getting it mounted, then the wiring would be simple if you dropped the cash for stand alone, but I would think the wiring would be pretty easy with stock harness anyways. Which one would you be swapping TT or T
Old Jan 19, 2004 | 07:00 AM
Sil40_Mayhem's Avatar
somethink like this:
13B in an S13 Silvia
Old Jan 19, 2004 | 03:45 PM
niz_sport's Avatar
hey sweet, you found it. Yea, I'd go with the older motor due to cost of the motor. SO a turbo II motor from an 89 or newer. What magazine is that out of sil40?
Old Jan 20, 2004 | 04:39 AM
actually, i found it on Meggala (look in the 'Hybrids' section).
Old Jan 20, 2004 | 12:57 PM
niz_sport's Avatar
thank you
Rotary_tech
Aug 2, 2008 09:06 PM
battlestylespl
Mar 4, 2007 06:56 AM
myshtern
Sep 12, 2004 06:31 PM
nismo240sxse
Apr 1, 2002 04:56 PM
SR20VET
Feb 8, 2002 07:09 PM
