s-13 swap questions...
Old Feb 2, 2003 | 09:52 PM
EkztremeRedline's Avatar
alright im getting my s-13 front end conversion in june, but the sr20 is gonna be in, in late april. my question is that my tranny that i have in the car now, is a automatic, the sr20's come with the 5 speed, what will i have to do when the sr20 is in?
thanks chris
Old Mar 4, 2003 | 12:41 PM
rbboyl's Avatar
Regulate
wrong forum. This should be under engine swaps.
Old Mar 4, 2003 | 12:56 PM
Justin.b's Avatar
You will use the tranny from the SR.
You may possibly need the driveshaft from a manual car as well, but I'm not positive if the driveshafts are different lenghts for manual/auto.
Other than that, it shouldn't be a problem. You can leave the electronics from the auto tranny in place - they won't mess anything up, and you'll be using the SR ECU anyway.
Enjoy... I wish I had a swap to loom forward to this spring. Spent my SR money on an engagement ring a couple of months ago.
-Justin
Old Mar 6, 2003 | 06:49 PM
rps13 sr's Avatar
I'm doing one right now.. its kinda of a headache... you need clutch master cylinder slave cylinder(unless the sr already has it attached... jdm pedals dont work cause i've tried so i had to get another one... and yes u do need the drive shaft cause the auto one is too long or too short...i forgot.. but thats basically it
Old Mar 6, 2003 | 06:50 PM
rps13 sr's Avatar
-Justin
i'd say forget the engagement ring go for the sr... the ring can wait
Clarke240
Sep 25, 2007 03:38 PM
SilviaJai
Sep 23, 2003 07:36 AM
RacerTim
Jul 3, 2003 09:32 PM
DrftDmn
Jun 7, 2003 11:40 PM
beefcake6681
May 30, 2003 08:26 AM
