S13 Blacktop Vac lines and hoses.
Old Aug 22, 2005 | 05:44 AM
OBEEWON's Avatar
I've been looking for a diagram of the vaccum lines and hoses for the S13 blacktop with no luck. I was wondering if anyone knows where i can find one, or if someone has one. I dont want to stick anything in the wrong place and fwack some shet up. Thank you for your generous help in advance fellers.
OB
Old Aug 22, 2005 | 07:23 AM
2fast4y0u's Avatar
if im not mistaking...
http://club240.com/forums/showthread...vacuum+diagram
that should help you out
Old Aug 22, 2005 | 07:43 AM
OBEEWON's Avatar
thanks alot man, as for the wastegate, is really ok if i plug it into the throttle body? if so which outlet should i use? im guessing not the one for the carbon canister.
Old Aug 22, 2005 | 07:57 AM
OBEEWON's Avatar
2 fast could you send me a few shots of your engine bay? you put in an s13 blacktop too right? im trying to figure out where ima put this big brass piece thats attatched to the harness and a few other neuances.
Old Aug 22, 2005 | 09:51 AM
2fast4y0u's Avatar
i do not have a black top but it is the same set up as i have...mine is red top...
email me at jayyaggie@gmail.com
bodiesenmotion
Feb 17, 2006 12:30 AM
sr20 1989
Sep 5, 2004 06:07 PM
s14kaibigan
Mar 28, 2004 04:48 AM
tegg_gsr
Feb 20, 2004 03:15 PM
