S14 SR20DET won't start
Old Jun 14, 2005 | 01:11 PM
jedimastereric's Avatar
Hello everybody! Well i put my S14 SR20DET into my 95 240SX and it will crank but not kick over...any ideas as to where my problem might lie? Any help would be appriciated. I figure it probably is a fuel problem or ignition problem but don't know where to start. Thanks for you help!
Old Jun 14, 2005 | 01:26 PM
2fast4y0u's Avatar
check the crank angle sensor to make sure its plugged in all the way. something so small wont let it start. also, are you building oil pressure.
Old Jun 17, 2005 | 09:22 PM
ILL egaL 240's Avatar
it happen to my friends sr cam angle distributor.
Old Jun 17, 2005 | 09:47 PM
Shri222's Avatar
ignitor chip?
Old Jun 19, 2005 | 11:03 PM
redtopS13's Avatar
this might help
http://www.zeroyon.com/TheSite/techservice.html
Old Jun 19, 2005 | 11:17 PM
Skiboard06's Avatar
first check if your getting spark in your coilpacks when u crank the car over u can do that by trying the old screwdiver in the coilpack next to the valvecover trick then take out injectors and see if there is fuel or if u can smell fuel on them
Old Jun 20, 2005 | 09:09 AM
redtopS13's Avatar
make sure you have the CAS set right. You can do this by setting the engine to tdc on the compression stroke, which is the second timing mark from the left on the harmonic balancer, and you have to take off the valve cover and make sure the cam lobes for the #1 cylinder are facing AWAY from each other. Then, unbolt the CAS and pull it out. Make sure that the yellow dot on the CAS is aligned with the little groove. Then, stick the CAS back in, and it will automatically turn to 15 degrees BTDC when it goes in. That should set your timing pretty much right on.
Old Jun 27, 2005 | 03:42 PM
would the cas being off adjustment cause it not to spark at all?
Old Jun 27, 2005 | 04:15 PM
2fast4y0u's Avatar
its possible.
Old Jun 27, 2005 | 04:40 PM
well I tested if the plugs are sparking and they aren't. Suggestions for what to do next?
Old Jun 27, 2005 | 10:01 PM
cheapystyle's Avatar
youre ignitor working?
Old Jun 28, 2005 | 02:40 AM
Levi SPL S14's Avatar
check the wiring make sure your ignitior is getting power.
Old Jun 28, 2005 | 06:03 AM
i have 2 ignitor chips here. they both have the same effect while trying to start the car. how can i check to see if the chip is getting power. Also can i get a code from the ECU on what the problem may be?
Old Jul 7, 2005 | 10:29 AM
Z-bra's Avatar
Does the sr have coilpacks?
Old Jul 7, 2005 | 10:32 AM
Skiboard06's Avatar
use a multimeter on the outlet of the ignitor chip and see if it is displacing voltage
redline88
Jan 17, 2006 09:31 AM
bm9201
Apr 16, 2005 09:56 PM
viridion
Nov 9, 2004 11:00 PM
Ricky240sx
Feb 15, 2004 09:29 AM
HotSaUcE
Jun 17, 2003 06:11 PM
