s15 sr20det into s13
Old Jun 21, 2004 | 11:05 AM
sidewaysilvia's Avatar
Hey whuts up guyz.. Need some info pronto!! Just bought an s15 clip.. I am familiarized with the driveshaft and engine/tranny mounts somewhat.. Can anybody elaborate on what needs to be done to complete an s15sr20det into an s13 chassis(fb).. Thankzzzz
Old Jun 21, 2004 | 09:49 PM
PANGES's Avatar
wire harnesses need to be "connected"
Old Jun 22, 2004 | 06:14 AM
Not sure if I understand .. What harnesses need to be connected.. I figure if I have sr20 harness with matching ecm.. Then that would be one harness that needs to be connected to corresponding sr parts???
Old Jun 22, 2004 | 07:27 AM
Thanks 4 input panges! Can anyone give me a detailed summary of the difference between the s13sr20 swap and s15sr20 swap (into s13 chassis).
Old Jun 22, 2004 | 10:22 AM
This is from Phase2motortrend, don't know if it will help at all:
S15 SR20DET:
We do not recommed installing the S15 SR20 motor due to high cost and time consuming install. S15 utilize a somewhat capable 6spd transmission with their speed sensor relocated to the rear differential. Be sure to get the complete rear end and drive shaft along with the S15 motor package, otherwise install will not be complete. The ignition coil is further advanced compare to S13/S14 SR20DET with the ignitor chip built into the coils, so one will not find/need the ignitor chip found in S13/S14 SR20DET. One can also upgrade to the S15 SR20DET ignition coils provided they are capable to wire it into their existing S13/S14 SR harness. We can perform S15 installs, usually price is about $500 more than S13/S14 install. Also speedometer is not compatible with S13/S14 gauge cluster yet until we figure out how to make the signal compatible with the S13/S14 gauge cluster. However air conditioning and the rest is not a problem.
BUCKY
Feb 11, 2009 10:01 AM
Alkaemy
May 5, 2008 05:16 AM
CWD240
Dec 29, 2006 04:53 PM
TruDirtyPlaya
Jul 8, 2003 08:46 PM
LADrifter
Mar 28, 2003 03:19 PM
