S15 SR20DET into S13
How difficult would it be to put an SR20DET w/ 6speed into an s13 chassis. i know some mounts will need changed, and all the ecu harness and such will come with the engine. other than that, is there any issue I'll need to consider?
ok beside the additional hp and Valves system ( not that much).... its not even worth it... to waste your money on the motor is pointless.... however someone who has SR exp. will chime in.
Google it.. i know i could find it bro... some of you newer guys need to learn how to source info.. searching is very very simple
