SOHC Tach Problems
Okay, I've done the search. Just to confirm. Options to get the tach in my SR20DET swap into a US 1989 s13 chassis.
1) Get an external aftermarket Tach
2) Get a JDM cluster
3) Get a USDM DOHC 91-94 cluster.
Question on option 2 and 3. I had someone tell me that the JDM cluster needs to have pins redone to get it to work properly. The USDM DOHC... is that a plug and play? Or is there more I need to do?
Thanks in advance.
Thanks in advance.
I just swapped my '90's speedo into my '93 180SX jdm cluster and put that in no problems. Only kouki ('96-'98) 180SX clusters need wiring to work and their tachs don't swap into us or earlier jdm cluster with out custom work either.
loc_staa05
Jan 12, 2007 03:16 AM
