SR and KA wiring
Old May 13, 2004 | 11:47 PM
gerbort's Avatar
SR and KA wiring
I have a cut lower alternator\trans. wiring from an sr and uncut lower wiring for a ka...should i just use the wiring from the ka and swap plugs so that it will match up with my sr alternator and starter? If so, how would you wire it? I need to use the ka speed sensors as well in the sr right?
Old May 14, 2004 | 05:06 PM
UndecidedPsi's Avatar
I believe you use the KA lower engine harness on the SR but you will have to swap out your speed sensor. The Alternator/starter wires should hook right up, I had to bend the two fins on my alt ring to get it to tighten down and I believce I had to cut and swap the starter wire from the KA to SR. Real simple to do, just make sure you soldier it.
boosted-alty
Feb 15, 2007 12:08 PM
remi
Jul 20, 2003 07:39 PM
positron
May 11, 2003 02:04 PM
konseiEva
Jan 21, 2003 11:13 PM
encasemyheart
Oct 12, 2002 05:18 PM
