SR woes. Loud tapping sound under valve cover.
Old Oct 8, 2004 | 05:54 PM
89s13drifter's Avatar
About 2 weeks after replacing a failed injector Im getting this loud rapid tick from under the valve cover. The car has been hard to start in the mornings as well. The sound starts once the car starts to get warm and when it is warm. For a few days it went away but now it just getting worse and worse. I have changed the oil twice since the failed injector flooded the cylinder and pulled the valve cover to see if anything looked wrong but nothing seemed bad. Today I looked down at the boost gauge and at idle it was only reading 10 in/hg instead of the 18-20 it normally reads.
The car is still running quite strong though so I am puzzled as to what it is. It sounds bad though. Any help would be greatly appreciated.
Old Oct 8, 2004 | 07:03 PM
iroc07's Avatar
it sounds like a sticky valve, but who knows. Did you try flushing the motor? that might break up gunk if you have something sticking.
Old Oct 12, 2004 | 10:05 PM
I did a chemical oil flush a few times and cleaned the oil pan. Then filled her up with some new 10w40 and the sound has subsided greatly. Its still a bit difficult to start in the mornings but that may be related to a possibly weak battery as the auto seatbelts are very slow in the mornings too.
x3240racer
Apr 12, 2006 06:48 AM
birgir185
Oct 14, 2005 08:04 AM
3825
Dec 1, 2004 04:52 PM
loafmaster
Sep 12, 2004 12:09 PM
