SR wont crank, need help plzzz!!!
Ok just finished up the swap, this car had an SR running it previously. Same starter. Its getting power, and signal.. I tested it with a voltimeter, the ecu signal is getting there, and power is. I took the starter out and had autozone bench test it.. they said it passed and it should be fine... anything else not cause to crank? All i hear is a click, but when i take my foot off the clutch theres no click, so the clutch switch must be working. SR gurus help!
