Sr20 no spark, Need help please!!!
Old May 22, 2008 | 08:46 AM
slowpokee's Avatar
so the situation is:
-the motor is cranking
-it only cranks when i do a direct bypass from starter to starter, which means when i turned the key nuthing
-but no spark
-fuel pump is coming on
-but cylinder looks dry
im going to guess that its bad ignittion signal?
but i check all my wiring again and everything seems to match up correctly.
any suggestions?
Old May 23, 2008 | 10:23 AM
S14.5 Silvia's Avatar
I had the same problem on my first swap ever, it ended up being the harness conector up in the dash. also follow all of the connectors from your coil wires into the firewall. my gues would be that harness though, especially if you have no spark and the ingnition appears to be faulty. HOPE THIS HELPS.Good Luck!
Old May 23, 2008 | 10:17 PM
slowpokee's Avatar
thanks ill re check the wiring again...
yea i really hope it helps too!
its giving me a headach!!
hatchbackheaven
Jul 21, 2008 04:30 PM
nschultz0124
Aug 15, 2005 05:47 AM
KeN VeRsUs RyU
Jun 2, 2005 08:02 PM
japporeyser
Apr 7, 2004 08:15 PM
tnd240
May 1, 2003 08:20 PM
