S14 SR Problems
Old Apr 18, 2008 | 09:27 AM
90 Sileightyguy's Avatar
S14 SR Problems
Ok, I am posting this for a friend. We are trying to get his car running but to no avail. What we have is that about 4k it hits a wall and starts bogging really bad. The only question I have is will a SOHC MAF work on a S14 SR? That is what was on it when he got it. Also I really didn't understand but we checked his timing and set it to 15 and when I plugged the TPS back in it advanced the timing to like 22??? Could it be the TPS? Voltage is .58 closed and 3.99 WOT.
Thanks
Old Apr 18, 2008 | 10:34 AM
JonathanRuiz's Avatar
sure timing is right?
Old Apr 18, 2008 | 10:52 AM
Set it to 15 myself. Second notch from the right.
Old Apr 18, 2008 | 11:58 AM
crazydrifter's Avatar
a bad vacuum leak maybe?
Old Apr 29, 2008 | 06:04 PM
broke240sx's Avatar
hey Sileightyguy did your friend get the problem fixed? im having the exact same problem and dont know how to fix it
Old Apr 30, 2008 | 06:45 AM
CharlesJ's Avatar
Club240 Staff
s14 ecu requires s14 SR maf. Sohc will not work. TPS is fine. Timing can do it too, but sounds like the MAF. Did this car ever work right? Also, does it have an S-AFC?
Old Apr 30, 2008 | 11:03 AM
No, we haven't fixed it yet. We are waiting for the SAFC and will let you know how that goes. The car has never really ran right.
Old Apr 30, 2008 | 12:19 PM
CharlesJ's Avatar
Club240 Staff
Then i would say the maf for sure. By running an afc, you can set the input maf as the s13 one and the output as the s14 which should make it run. However the sohc maf still sucks and you need either a proper s14 or z32 w/afc. That may not be your only problem though
Old Apr 30, 2008 | 07:49 PM
He put the Z32 maf on it today and it idled great but when he drove it the bogging was still there. He does not really know how to set up the afc so any pointers would be great.
Old May 1, 2008 | 06:34 AM
CharlesJ's Avatar
Club240 Staff
Yeah, the Z32 will not work unless set up correctly in the AFC. You need to read the directions and set it up for the correct MAF, and then change the in and out. In will be the number associated with Z32 and out with the S14. If memory serves me, it was IN 2 OUT 5.
Old May 24, 2008 | 05:02 PM
sbanzer123's Avatar
have you checked for leaks around the exhaust mani.
Enlefo
Oct 13, 2005 11:35 PM
hotimportknight
Jan 9, 2005 10:58 PM
pignose
Dec 15, 2004 11:01 PM
james_s14
Aug 13, 2004 12:41 PM
s14joe
May 18, 2004 09:42 PM
