sr20det is finaly installed. cranks but doesnt start up?
Old Aug 17, 2006 | 10:25 PM
spoolin240's Avatar
I tried to start it up today and it cranks but for some reason it doesnt start up. The ecu code I got with my engine set is #25 is that the right ecu? I think that might be my problem. I also didnt change the spark plugs that came with the engine set. But I thought atleast one or two whould spark and make the engine start up. Any Ideas? I think it might be the wrong ecu?
Old Sep 2, 2006 | 05:54 PM
thang nguyen's Avatar
go ahead and change the spark plugs, since it would be wise to do so. AS fas as yourstart up problem, check if the oil pan is dented or damaged. (most SR oil pans are regularly damage on shipping.) Mine was dented but hardly noticable when i installed and it pluged up the oil sump and the no oil was flowing through out the engine. if it is dented remove and bang it out or replace and should solve it.
Old Sep 5, 2006 | 10:54 AM
rps13 sr's Avatar
umm i dont think the dent in oil pan causes startup problems.. i think it will just starve the motor of oil if u start the car.. not being able to start the engine is another problems as such as fuel spark timing and such.. check to see if ur getting spark and if ur getting fuel..
Old Sep 5, 2006 | 12:14 PM
oh yes. that was an incorrect diagnosis by me. mine started but had loud knock in the head of oil starvation. but start with RPS13's advice then check to see if the ignightor is faulty or broken.
Old Sep 9, 2006 | 01:58 AM
bleachcola's Avatar
did u check if u are getting spark? what about fuel? might be the injectors, i had a similiar problem
Old Sep 24, 2006 | 09:01 PM
silentvoice19's Avatar
i thought the #65 was the right ecu for a redtop sr20det????
positron
Oct 17, 2007 04:36 PM
ZKaosKid
May 30, 2006 08:39 PM
KA240
May 31, 2005 03:30 AM
holman00
Apr 29, 2004 06:22 PM
holman00
Apr 16, 2004 09:03 PM
