SR20DET in MO
here is how I found a few sellers near me... search on Ebay within your state (using advanced search)
I did this for you and found Anarchy Motors http://stores.ebay.com/Anarchy-Motor...toreviewQQtZkm
I cannot vouch for them, but there ya go
if you are located anywhere near st. louis there is a store around here that sells clips and set engines. They can also install them. The website of the store is www.adrenalinexxx.com check it out
I have the engine torn apart.
S13 Redtop
Head has been resurfaced and cleaned up.
Block is stock
Have stock rods
Have cams
Have IM, EXT M, Turbo, O2 housing
Pretty sure I still have oil pump, maybe water pump.
I also have a set of crower rods
S13 Redtop
Block is stock
Have stock rods
Have cams
s14Drifter
May 25, 2009 12:35 PM
