Swap to a RB20DET
Old Feb 27, 2002 | 11:16 PM
Driftin180SX's Avatar
Swap to a RB20DET
I was wondering if it was possible to do an engine swap from a KA to a RB20DET in mah '93 240. Is there ne modification dat would be needed to be done? thx for the help.
Old Feb 28, 2002 | 02:14 AM
battlestylespl's Avatar
go to: www.unstable-hybrids.com
they did one. i don't really see the fuss in the RB20, since it doesn't really have as much backing as the SR, not in the states anyway.
Old Feb 28, 2002 | 07:29 AM
LI S13 Blacktop's Avatar
that motor isnt all that great. Its too old school, get a rb26dett.
Old Feb 28, 2002 | 02:18 PM
Sinfestboy's Avatar
the 26 needs too much work, go with RB25DET. TT is to big, too.
Old Feb 28, 2002 | 03:26 PM
So wuts some good things bout a RB25DET? would it take up as much room as a SR20? or even more?
Old Mar 1, 2002 | 12:08 AM
it would take alot more power before you'd have to sleeve it. once you get to about 450hp on an SR it needs to be sleeved
Old Mar 1, 2002 | 10:27 AM
Sinfestboy's Avatar
whats good about RB25DET? well... lets see.... its like an SR20DET.... WITH 2 MORE PISTONS. but it is an RB series motor, I dont know whats diffrent between the two.
Old Mar 5, 2002 | 09:00 AM
Its a six cylinder.
The aftermarket parts availability isnt as great as the market for SR parts.
Old Jul 21, 2003 | 12:53 PM
DC2R Munky's Avatar
Then why would someone get a RB20DET over a SR20DET? Can the RB20DET handle more boost than the SR20DET? If so, how do you know, and how much more on stock internals? I am really interested in finding out because I am considering both engines at this point.
Also, are there fitment issues with the RB20DET that you wouldn't have with the SR20DET? It seem like there would be. It would also seem like the weight balance of the car would be better with the SR engine. Is this true or no? How much does the RB weigh compared to the SR?
I know what SR20DET's sell for these days, but what about RB20DET's?
Sorry for all the questions, and thanks in advance for the help.
Old Jul 21, 2003 | 01:51 PM
SHIFT_Lock's Avatar
rb 20 clips go for 1000-1200 same as a ca.
i shall post my usual info about the weight diff hold up lets see here we go:
"that has absolutely nothing to do with anything what so ever.
Ever see the jms rb20s13? a typical rb not the 26 weighs about 50 lbs max over a ka. take the battery throw it in the trunk. remove the following: front bumper,ac dryer,ac condesor,charcoal can, old mechanical fan,ac lines,battery tray, window washer bottle,ac fan. and also if it's a s13 if you do a silvia convertion that will lose 27lbs also.
another thing if you use mounts IE -UH- or mckinney the motor will sit lower and back which also helps weight dist.
i hear this weight dist. bs agument all the time. and even from people who pull the whole interior and that can mess up front to back weight but it doesn't matter."
i quote this alot i see the argument everywhere.
also mounts from mckinney or -UH- help alot it makes it a drop in affair.
Old Jul 21, 2003 | 07:09 PM
DC2R Munky's Avatar
OK...I'm left to ask the same question I asked in the other thread:
Why would anyone get the SR20DET over the RB20DET? With the capability for more power, one would think it the superior engine. Do people get the SR20DET because it has more power initially?
Old Jul 21, 2003 | 07:37 PM
SHIFT_Lock's Avatar
nope ...people are blind ,and the rb20 has more power to begin with ...220 VS. 205. this is a question i ask myself every day.
Old Jul 21, 2003 | 08:14 PM
people get the SR mostly because its the most popular swap there is out right now, and its the one that most shops do. There isnt many people that can do the RB swap out there.
Old Jul 22, 2003 | 07:24 AM
Doba's240's Avatar
wiring up a SR20 people say is hard enough, wouldnt an Rb engine be even more difficult to wire up?
Im going through the same debate right now, considering the SR or the RB, im constantly seeing threads with people having problems with their SR, maybe cause theyre trying to put out too much power with stock internals.
The thing i hate the most is hearing people putting in an SR and when they go to start it ..click.click..a big nothing.
I think its going to happen to me....NOooooooo.
what to do?
stick with KA and just add Turbo, cause my engine has 210km but i know it works fine. I put in an SR with 75km and ohhh **** it wont start.
Old Jul 22, 2003 | 08:38 AM
DC2R Munky's Avatar
OK...maybe I am confused as to why people pick SR's then...
Is the RB harder to wire than the SR? If it is, what sorts of wiring guides are available? The guy helping me with the swap is an electrical engineer, the other guy is a mechanical engineer, and I am mechanical as well, but I suck at wiring!
Are there still not fitment issues even with the UH mounts (turbo, hood, etc.)? How much do those cost incidentally? Even if they are somewhat expensive, you could easily pay for them in the money you save on the swap itself.
It seems like I am leaning more toward the RB20 now. As for the SR's being more "popular," that would be more reason for me not to get it.
