Tach/Temp Gauge not working
I just purchased a 92 240sx yesterday, and the tach and the temp gauges do not work, the car has a sr20det engine swap.
I was thinking of just replacing the gauge cluster, if anyone has any idea of why it does not work, as I am new to nissan's and was a honda person who swapped a crx.
So, i should check the wiring where?
Behind the gauge cluster?
And do I have to run some wires from the ecu?
Thanks, ill be taking the cluster out tomarrow, because the previous owner has white face gauge overlays on it.
So I can take em out lol.
Originally posted by nsn240
wow... under the kickpanel on the passenger side.
the tach should work because its a 92.. something is wired incorrectly, same with the temp sensor. check wiring, fuses, ecu, temp sender etc
Just got into the nissan game, and now im trying to learn.
Where is the temp sensor located?
