What oil Grade for sr20det?
Old Oct 3, 2004 | 10:03 PM
james_s14's Avatar
just wanna know what grade and brand oil people in so cal are using for an s14 sr20det? ive also got a faint click in the engine, sound like its comming from the top of the engine, its not real loud but its kinda annoying..also, are iridium spark plugs any good for my engine?
james_s14's Avatar
by the way, im using mobil 1 10w30 synthetic.
Old Oct 3, 2004 | 10:16 PM
My buddies that run S13 SR's run 10W30 in their motors with no problems. Some even run 5W30.
Is the slight tick just during start up and at other times as well?
Old Oct 3, 2004 | 10:26 PM
rkcarguy's Avatar
I kinda like the Mobil-1 0w-40 myself. Thin oil weights are better for cold climates and gas mileage/emissions more than making your engine last longer.
Old Oct 4, 2004 | 06:11 AM
srslider's Avatar
Alot of how oil affects a car is based on the climate and how the car is driven. The first # in line is the base viscosity, its what the oils weight is cold. The thinner the oil the more likely you are to spin a rod bearing or something of that nature. The thicker the oil the more crank drag your going to get in the pan but IMO its safer than it being to thin and breaking something. I also drive hard and have been through 5 ka's before my SR. I personally run 20w50 now but I also live in the south.
Old Oct 4, 2004 | 10:24 AM
james_s14's Avatar
i dont drive my car hard at all, sometimes i feel like punching it though. anyways, the click comes at start-up. its not very loud but its very noticeable. after it warms up and i leave the turbo timer on, ill be walking away from my car and i can hear it. sometimes i cant hear it though. its weird. one of my friends told me i needed a valve adjustment, bad thing is, whatever i need, i dont know how to do it. i dont know anything about these cars since im a newbie to 240s.
Old Oct 4, 2004 | 12:55 PM
james_s14's Avatar
btw what type of spark plugs should i use for my engine..its pretty much stock except for a few things..look at my signature
Old Oct 4, 2004 | 08:26 PM
TWT00's Avatar
Im running 15W50 fully sinthetic now with no problems. Also using the NGK iridiums.
Old Oct 4, 2004 | 09:27 PM
james_s14's Avatar
i heard iridium plugs dont do well @ high rpm..at least on an rb26..they say the best is to use the regular plugs..
Old Oct 4, 2004 | 11:43 PM
xjon's Avatar
RB26- completely different engine. Mckinney recommends the thick stuff for these engines. BUt SR's can go thin. I am using 20w50 in my RB25.
I was using the Iridiums in my RB25 but switched to autolites since I needed to gap the plugs tighter. My spark was being blown out at >10 psi. Also I was told, you're not suppose to gap the iridiums. I also talked to Powel who does these RB swaps and he recommended the copper plugs.
But for the SR's, I don't know.
Old Oct 5, 2004 | 01:12 AM
james_s14's Avatar
what are the specs for gapping spark plugs for an s14 sr20det..any know? also, what kind of oil filter do i use, and anyone know how to wire s15 headlights to the s14 wire harness?? do the s15 lights even have the orange colored running lights like american cards do? cus, on mine (oem) theres the projection light, high beam, and theres another light in the middle, but its clear, not orange..
Old Oct 5, 2004 | 01:13 AM
james_s14's Avatar
what are the specs for gapping spark plugs for an s14 sr20det..anyone know? also, what kind of oil filter do i use, and anyone know how to wire s15 headlights to the s14 wire harness?? do the s15 lights even have the orange colored running lights like american cards do? cus, on mine (oem) theres the projection light, high beam, and theres another light in the middle, but its clear, not orange..if someone can answer all these questions, they are THE MAN. thanks guys.
Old Oct 5, 2004 | 09:53 PM
stannyboy's Avatar
I recommend mobil 1 5w-30.. why because my buddy got his sr before any of us got it.. and thats all he's been using.. no motor problems what so ever. And still runs strong as hell.
Old Oct 5, 2004 | 09:54 PM
stannyboy's Avatar
oh forgot to mention he's had it for about 6 years already. Also everyday driver.
Old Oct 9, 2004 | 09:23 AM
james_s14's Avatar
no one knows the gap settings for s14 sr20det spark plugs?
