Where can i get RB20DET Aftfermarket Parts for S13 swap?
I see that Night7Racing sells the motor mount kit which is what im gonna pick up if I go RB20 but where can i get things like downpipes and test pipes? Also, can i use the S13 Greddy V-SPL intercooler kit or will i have to custom make all the piping?
Thanx
Dustin
Thanx
Dustin
YOU CAN USE THE R32 OR R33 V-SPL KIT AND IT'LL WORK BUT NOT THE S13 SR ONE AS IT IS TOTALLY DIFFERENT PIPING ROUTES. ANY R32 OR R33 DOWNPIPE WILL WORK WITH THE SWAP, AND YOUCAN USE A S13 TEST PIPE WITH OUT ANY PROBLEMS.
DON'T BUY ANYTHING FROM NIGHT7RACING UNLESS YOU PLAN ON GETTING RIPPED OFF.... OHH AND I BOUGHT THOSE MOTOR MOUNTS AND THEY DIDN'T WORK FOR ME.
Re: Where can i get RB20DET Aftfermarket Parts for S13 swap?
Thanx
Dustin
Thanx
Dustin
Or get a swap with a crossmember and ditch the mount kit idea. I don't plan on messing with the motor mounts unless I have to on my swap, and even in that case they look easy enough to modify the existing motor brackets instead of blowing $500 on a kit. That can get you a nice T3/T4 upgrade instead
I was looking at my motor mount brackets on the RB and was thinking about removing th slotted plates, cutting the brackets shorter, and then rewelding the plates placing the motor lower and back a little more. I can just slot and space the rear tranny brace to fit from there.
are you guys saying I cant install my RB without cutting into my hood brace and making the job look like a hacked up mess???? that would really **** me off. I thought I could use the stock motor mounts and just modify my Xmember. if anybody could give me a DETAILED answer I would be greatfull. remember talk slow and use little words, your dealing with a chevy guy here, I am not that quick on the up-take with this import stuff yet.
dd240sxdd
Nov 19, 2006 10:01 PM
MasterOSkillio
Jan 17, 2006 02:13 PM
iroc07
Aug 29, 2004 04:09 AM
