Will a S13 tranny work on a S15 engine?
Old Feb 14, 2003 | 11:02 PM
beefcake6681's Avatar
Question Will a S13 tranny work on a S15 engine?
I am able to acquire a S15 engine with ECU and harness. I am aware of the amount of work required to fit a S15 tranny into a S13 chassis so I am planning to buy a separate S13 tranny from a redtop SR20DET. My question is, will a S13 tranny work without any problems with the S15 engine and what modifications are needed if any?
.......................................... Thanks,
Old Feb 14, 2003 | 11:20 PM
I'm with Stupid's Avatar
It bolts right up.
Old Feb 15, 2003 | 08:00 AM
kaos's Avatar
actually it is kinda common to swap out the 6 speed and put the 5 speed just because of the stronger gears.
Chad
Old Feb 15, 2003 | 10:07 PM
Justin.b's Avatar
I think you either need the tranny or rear end from the S15 for the variable valve timing to work properly. I think this was true with the S14 at least. Check with www.heavythrottle.com and they'll be able to tell you exactly.
-Justin
Old Feb 18, 2003 | 12:41 AM
S15 Powered's Avatar
You need the differential, not the tranny.
Old Feb 18, 2003 | 07:23 AM
Justin.b's Avatar
Thanks - I knew it was one of those.
-Justin
Old Feb 18, 2003 | 06:10 PM
-Justin
No problem, that's what we're here for
Old Mar 1, 2003 | 03:36 PM
altima/240sx's Avatar
I drove a 92 S13 with a S14 tranny installed. I didnt like it. it had horrible low end power. I don't know if its the engine or the tranny's fault, but top end, it was really nice.
d4rkpri35t
May 7, 2006 11:07 PM
Xren17
Jan 19, 2006 08:55 PM
JDMLyfeStyle
Dec 19, 2005 06:08 PM
CarObsessed
May 12, 2005 05:11 PM
eddawg S13
Dec 15, 2004 08:04 PM
