all inside power gone
Old Nov 9, 2009 | 12:05 PM
Nismo2205's Avatar
i wanted to know why when i turn my car off i lose all power inside like clock and my lights from the inside dont turn on. and when i trun the car on it like resets the clock and everything
Old Nov 9, 2009 | 03:26 PM
check your grounds... sounds like something is lose.
the major ground is your chassis body from your battery... should be a thick cable that is either black with red stripe or black with yellow stripe.
Old Nov 16, 2009 | 08:05 AM
Nismo2205's Avatar
ok thanks i will take a look at it... do you think it might have to do with the radio it happend after i installed my stero
Old Nov 17, 2009 | 05:01 AM
Preston's Avatar
You wired the stereo wrong and switched memory (yellow) with ignition (red) on the radio when you wired it in. Recheck your wiring...240's can be a pita if you're not familiar with them a lot of stuff runs through the radio wiring.
Old Nov 30, 2009 | 08:28 PM
Nismo2205's Avatar
cool good lookin.
unknown2k1
May 16, 2005 12:25 AM
SoCalude98
Apr 2, 2004 11:02 AM
RNN14
Apr 26, 2002 05:22 PM
bigbird
Feb 7, 2002 11:10 PM
