Steering wheel spline
Old Jan 24, 2009 | 09:40 PM
Alexl08's Avatar
I had bought a roller s13 and it had no wheel on it and not thinking unloading it i used vice grips to steer the car and the spline is all chewed up so now what can i do?
Old Jan 25, 2009 | 01:40 AM
that was a very bad idea...... you have to install a new steering column.
Old Jan 25, 2009 | 09:45 AM
your supposed to put a rag over it and not use too much pressure.....
Old Jan 25, 2009 | 03:48 PM
Alexl08's Avatar
can i not just replace just the spline section insted of the whole column
Old Jan 25, 2009 | 04:36 PM
Of all of the items I have replaced/broken on my car, a steerign wheel spline is not something that I and or others have messed up.
It is not a hard task, you will however have to remove all of the wiring and your locking mechanisim. since it is a shell, you can easily get into the engine bay and disconnect the shaft and pull it through.
once again i have never done it, best bet for you would be to consult the FSM in the steering section and look for an exploaded example of the system. I can almost bet that you will have to go to the junkyard to remove the column.
onevia
Aug 26, 2006 08:17 PM
Bryan
Jan 24, 2006 11:54 AM
JDMxDrift
Mar 5, 2005 01:50 PM
S13FREEAAK
Jul 22, 2004 09:37 PM
Strizzy
Aug 27, 2003 12:34 PM
