300zx Fuel filter?
Old Jul 6, 2005 | 06:03 PM
ConceptS14's Avatar
how about some seafoam before you change everything out?
Old Jul 6, 2005 | 06:29 PM
When changing the fuel filter be sure to remember to take out the fuel fuse.
Old Jul 6, 2005 | 07:54 PM
Atown 240's Avatar
Ur joking right?
Old Jul 6, 2005 | 09:01 PM
jbask's Avatar
hahahaaaaa.
but take the feul cap off 1st. other wise there will be fuel presure and you will squirt gas all over. don't ask how I know
Old Jul 6, 2005 | 09:16 PM
Atown 240's Avatar
lol, i figured it was some newb thing. I'm like fuel, fuse, those dont go together. So if i take off the gas cap i wont spill everywhere. lol. Also fuel is spelled wrong in ur sig. Why does the tank always suction all the air when u open the gas cap?
Old Jul 6, 2005 | 11:23 PM
Atown 240's Avatar
damn this forum dies at night
Old Jul 7, 2005 | 02:13 AM
lrb_2000's Avatar
yes it does.. and that's when i'm on the most. :P
I changed my cap/rotor/wires/plugs at the same time.. .might wanna check your air filter...if it's cone filter, you might wanna wash it a little bit... I air my tires to 42psi, when it's hot out, they deflat a lil bit when it's colder... wee, good stuff.
Old Jul 7, 2005 | 07:30 AM
Um, there is a fuse running to your fuel line or something. You take it out when the car is running so that the car dies about 5 seconds after you take it out. Either do that or have fuel in your eye, it tends to burn btw.
Old Jul 7, 2005 | 08:38 AM
It'll be your fuel pump fuse, take it out so it shuts off. After the car burns the fuel that is remaining in the fuel lines it will die, then you can go about changing things
Old Jul 7, 2005 | 09:55 PM
Atown 240's Avatar
so as i was painting my valve cover today and replacing my v/c gasket, i was like hey, wheres the fuel filter. I think i found itbut i'm not sure. Anyone got a pic. I want to make sure i'm going to connect or disconnect the wrong thing. Also do you just loosen the fuel lines and pull? Anything to be cautios for
Old Jul 7, 2005 | 10:19 PM
  #26
ConceptS14's Avatar
on the passenger side. it will look exactly like the Z32 filter but smaller.
just yank the lines off and pop them back on.
watch out for fuel squirting out at you.
but you should release the fuel pressure before you attempt this.
Old Jul 8, 2005 | 12:52 AM
  #27
naptime's Avatar
from ********** faq
It’s on the right side of the engine bay (right side when looking out the windshield) attached to the strut tower about halfway down. It looks like a little silver can with one black hose going into the top of it and one black hose coming out of the bottom.
Take off the gas cap, take out the fuel pump fuse in the fuse box by your battery. It should show you where it is on the cover. (Note: Fuel Pump fuse is in fuse box by left foot in North American s14. Shawn Schembri)
Crank the engine and it should start, then immediately die. Loosen the clamp on the top hose and slide the clamp up on the tube, then tighten it so that it squeezes the tube shut a bit (not too much to rip the tubing!!), then do the same for the lower tube. Now mine was a ***** to get off because the filters have nipple like plastic tubes coming off the filter that can seize to the rubber fuel tubing a bit because the tubing gets hard over time. It took some effort to get the damn tubing off. (Note: Twist the fuel filter while holding the tubing. The twisting will help loosen the connection. Pulling straight out will only result in cut knuckles or a sore elbow. Resist the urge to use pliers on the tubing, it'll damage them and cause a leak. Dave Balingit)
Once they are off some gas will spill out so I'd put a old rag or towel underneath the filter to absorb any gas that spills. Oh, and don't smoke! (if you do)
Then put the new one in and attach the hoses. Re-tighten the clamps where they were on the original. Overall if the tubing comes off easily its a 15-20 minute job.
Kris -- 1990 240SX
These hoses are hard to remove.
Solution:
Pliers can and should be used. Just put several plys of tape or a towel over the rough part on the pliers. This will protect the hose from being torn and damaged. Then do some twisting and working of the hardened hose. Then finally you can pull off the hose. Never pull from the beginning. If you have enough slack just cut the hose ,which will give you a snug fit when you re-attach it.
Brett S.
Email: Phsinvent@aol.com
Can't get the top hose off?
Solution:
I just replaced my fuel filter again the other day and found that if you remove the bottom hose first you will then be able to pull the filter out and twist it away from the top hose - that's the one that gives us the most problems. After I slid off the hose clamp the bottom hose came off rather easily! BTW - Use the late model 300zx fuel filter as described in the Product Reviews, it really helped speed the revs up dramatically.
SteveD.F.
Email: stevend23@hotmail.com
Old Jul 8, 2005 | 07:35 AM
  #28
Atown 240's Avatar
Originally posted by naptime
from ********** faq
Kris -- 1990 240SX
Solution:
Brett S.
Solution:
SteveD.F.
Thanks, i'll be doin it today
Old Jul 8, 2005 | 09:47 AM
  #29
See, im not crazy. Who's laughing now? lol
Old Jul 8, 2005 | 10:33 AM
  #30
naptime's Avatar
no prob bob
