89 240sx
Old Oct 19, 2005 | 08:55 AM
butters's Avatar
89 240sx
is this a good year to buy?
im looking to keep the stock KA motor and build on that, s13 fornt end conversion and some wide body fenders. i found an 89 coupe for sale and im just curious if there is anything bad about this year.
thanks
Old Oct 19, 2005 | 09:31 AM
butters's Avatar
169k, $800 and the headlight motors dont work. and it has a little body rust......
ill have pics sometime soon.... im just wondering if its a good deal for this or not
Old Oct 19, 2005 | 12:41 PM
benziebbj's Avatar
I had an 89 and it was really good to me. I only had to replace a clutch and oxygen sensor..
Old Oct 19, 2005 | 12:43 PM
benziebbj's Avatar
My bad man didn't read your hole post... I got a 92 coupe white, perfect inside no rips and good exterior no rust, dent's etc.. The engine is locked up though...
wheres the rust at?
Old Oct 19, 2005 | 01:49 PM
butters's Avatar
you have it for sale?
im not shure where the rust is at. ill find out wheni get the pics. but im a little weary about the 169k....
Old Oct 19, 2005 | 02:01 PM
don't be weary, if the KA was taken care of it should still be running fine. My old 1991 had about the same mileage and the only thing that ever needed replaced was the thermostat. If the person maintained it, it should be fine.
But definately find out where the rust is
Old Oct 19, 2005 | 02:05 PM
butters's Avatar
where are the bad areas for rust?
if it has alot of rust or any type holes, im not going to get it
Old Oct 19, 2005 | 02:13 PM
butters's Avatar
is there anything bad about having the SOHC? or should i look for the 91+ years with the DOHC?
Old Oct 19, 2005 | 04:10 PM
butters's Avatar
rust is on the passenger front fender and rocker panel
Old Oct 19, 2005 | 04:44 PM
nsn240's Avatar
that's not too bad a place... just make sure you replace the whole area with new sheet metal... definatley check UNDER the car for rust too. There's nothing wrong with an SOHC, if you really want, you can swap the heads and make your single cam a double
Old Oct 20, 2005 | 09:51 AM
butters's Avatar
allright, i found a 93 with a blown head gasket. i heard that blowing the head gasket is a common problem with them. is this tru? i am just asking because i want to make shure that the only reason, not because it overheated or something.
this one is from texas and has no rust : )
Old Oct 20, 2005 | 10:12 AM
I dunno if its common, but depending on your mechanical ability it may be a decently expensive fix
Old Oct 20, 2005 | 11:57 AM
butters's Avatar
well, my father told me when engines blow a head gasket its usually caused by overheated and that may have warped the hear or maybe the block. so i figured to make it easier on myself, i called a motor rebuilder and got a price on a rebuilt motor. and wen he was explaining what they did to it, he mentioned something about an upgraded head gasket because over time it will deteriorate....
i am mechanically inclined once i figure it out, and understand it. wich i understand motors.... i work on my quad all the time. plus i can ask my dad if i need any help
as long as its just the head gasket i will have no problem fixing it. fund wise. maybe i can throw some cams in it while i have it appart. the 240sx area is fairly new to me so im not shure whats out there on the market. i can get it for 1800 OBO with 125k and no rust at all
Old Oct 20, 2005 | 12:03 PM
so is that $1800 with a blown headgasket? I would try to talk them down a little bit, that seems a little high to me for a car with that problem
