89 Automatic to stick transmission switch
Old Aug 17, 2005 | 07:43 PM
DraFt's Avatar
I'm thinking about changing my auto to a stick and im just wondering what all needs to be changed inorder to do this.. My friend said the drive shaft might be diffrent!! has anyone ever done this before ?
Old Aug 17, 2005 | 08:45 PM
toycar's Avatar
read the faq section
Old Aug 17, 2005 | 08:57 PM
Helghast's Avatar
Changing an Automatic to Manual is IMPOSSIBLE!
..I mean..it took me 1 day to do it.
SEARCH EET!
Old Aug 18, 2005 | 01:16 AM
lrb_2000's Avatar
i'll answer for you... searched, took me 2 seconds..
5 speed ecu S14's(optional on S13's)
5 speed trans
5 speed trans crossmember
5 speed driveshaft
manual flywheel with bolts
manual engine backing plate
manual trans to engine bolts
clutch with clutch bolts
(including pilot bushing ,driven disc and pressure plate)
clutch pedal
brake pedal(optional)
clutch line upper
clutch line lower
clutch dampner(optional)
cluth master
clutch slave
lower shift boot with plate(mounts on your tunnel)
upper shift boot (recommend purchase new )
ChadS.
Aug 1, 2005 12:27 PM
U_NeeKz
Jan 26, 2004 12:47 PM
gmckey
Apr 24, 2003 06:59 PM
anttoni
Jan 9, 2003 06:33 PM
anttoni
Dec 6, 2002 04:01 PM
